2002 wrx wagon
manual
115,00kms
wagon
black/blue pearl
3" stainless turbo back exhaust
HKS BOV
cold air intake
BSA 18's good tyres
1yr rego
2yr factory warranty remaining
excellent condition
$22,250
need to sell....
Edited by fix8ed
https://www.sau.com.au/forums/topic/154348-02-wrx-wagon-blackblue-tbe-bov-18s/
