Hey guys, umm it seems that my headlight on the RHS is nearly stuffed... My car was fitted with 50 watt globes and were very dull, almost dangerously dull, so i got some 100 watt ones and since then all hell has broken lose! Im not sure what is involved in the compliance process to fit globes that meet australian rules. But my mechanic has always seemed to have had a huge amount of troubble fitting the globes in the housing. Ill try describe it to everyone.
Theres a small washer that the globe sits in, round with one side squared off for the flat edge of the globe to sit agains, then both the globe and the washer sit back in behind the headlight unit. but with mine, there didnt seem to be an easy way to get the washer and globe to lock back in place, so that the globe is properly alligned. Now, when i had my 100watt globes fitted everything seemed to be fixed... nice clear bright lights, but about 1 week after they were fitted, i thought one had blown again, the right hand side one, but when i pulled the globe out to see why it had blown after only a week i saw that the washer has melted some how around the base bit of the globe. So it probly hasnt been sitting/alligned correctly since they were fitted, and the extra heat from the 100watt globes has melted the unique little washer thingy, and its stuck to the globe now....
I dont no wot to do.. The globe hasnt blown, but i think its shorting out somehow. Has anyone else experienced this at all?? How can i go about getting it fixed? Should i contact a compliance place and see if mine has been done dogely? Plz help.... im desperate!!
wat the hell is a washer bottle doing near the headlight.....is that normal?
100watt globe woulda melted the bottle and settled all over ur headlights.
best bet is to bring it to someone and try machine all that crap off......
gl man sounds bad.....
Well from memory theres meant to be a wire clip which folds back over the globe back .. I dont know what the hell happened to ur headlights but I got off lucky with my compliance...
Neways my advice is save up for some R34 GTR lights .. about $500-700 difference is they are black!! the surrounds .. Or even just buy a HID setup! group buy on here!
Why is it necessary to post things up in many different threads. It's just stupid mate.
I actually replied to you in your other thread, but I feel like deleting my reply now.
Anyways, I do research experimentation on optics and lighting circuitry, so if you need advice, pm me.
  • 4 months later...
dude ive got the exact same problem...
once u take it out u cant properly put it back in place again.
i did that mistake this arvo..tried to find out wat size my bulbs were..
took it out and the washer just came off..
tried to put it back in place again but my washer snapped. and the element inside the bulb snapped off from violent knocks.
its fking bullshit. i dont know wat to do now since the washer is FKED.
mine 2 is an r34
    • Middle seat good for a slab of beer or Esky for a road trip. 2x kids, means 1x free seat lol.
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
