T51R is what HKS call their versions of the Garrett GT42R , T51R KAI is similar to a GT4294R and T51R SPL similar to a GT4202R . Cartridge wise the main difference is that the HKS options use that 82mm GT42 turbine in 76 trim and Garretts market versions the 82mm GT42 turbine in 84 trim . HKS have also optimised their housings for petrol aftermarket apps .
First thing to know is which TO4Z ie HKS or Garrett marketed version and is it worth a try on the new engine first . What power characteristics are you trying to change ? What things are different about the new engine compared to the existing one ?
Also between the TO4Z and GT42R families is Garretts GT4088R which is worth a look .
Cheers A .
https://www.sau.com.au/forums/topic/154440-garrett-gt51r/#findComment-2872377
oh. garrett t04z .84 split.
new motor has mild cams and headwork. will rev to 8500 and will be using a good manifold. (once i make it)
oh just more pwer and i love the whisstle
so the hks versons use a more or less responcive turbine?
https://www.sau.com.au/forums/topic/154440-garrett-gt51r/#findComment-2872407
