That's right.
The compliers can't pass a car unless it's bog standard & they can prove that any mods have been removed & destroyed.
So they can't even sell the parts they take off.
Also, it means the customer has to pay for genuine parts to be fitted in place of anything that had been modified.
Its a rather crappy law now. haha i guess you could go over there, take the mods off (or get someone to do so there) and then container the whole lot over here.
Does anyone know when they will be allowed to resume importing and compliancing cars again? It would be interesting to see what happens in the next 12-18 months.... then again, it might not be.
why cant you buy a car through prestige, pick it and take it home. then you can spend as long as you like making it std and take it to say upi for compliance. then leave std for rwc and rego, and put mods back on after. would be good for say a supra: take of 2540s, cooler, bov, pod, mgt, and make std, then put back on. would be worth the hassle cause no aussies would be bidding on modded cars in japan so would be cheap as!
I would agree with Adam... it would take an exceptional car to make me import privately again. Too much b/s, paperwork, sleepless nights, running around.
But then again, I'd after a pretty stock 96/97 r33 GT-R V-Spec or series 2 r34 GT-t sedan... maybe but doubtful.
I know I got lucky this time, so did Frank it seems but next time...
T.
what exactly do u have 2 do over there for compliance ?
we have 2 do a SVA test here , Single Veichle Application .
basically , this involves the fitting of
1 ) fog light + illuminated switch + some amour around wires
2 ) spedo must read in MPH
3 ) fuel neck restrictor
then its stuff like emmissions , noise , tyre's must be eu marked now and basically no protrusions oh and we cant have turbo timer's fitted.
i have imported 2 now , yes its a long wait , well 40 days on boat
and have had the black one in my garage , for 6 weeks now , it may be road legal , in another month or so .
importing , is a very stessful thing , well the first time was , basically , apart from pics , " get pics of every thing even inside the boot " you are sending money blind, how ever i think it is worth it
Ours was less strict than yours. We didn't do emissions or noise. We are strict amount minor stuff like flat mirrors, seat belts, dash illumination, intrusion bars, fluid changes.
Most mods they did not care about and I can tell you that the stuff you can't readily check for was generally not done.
But like any business, there are way around inspections... with the right people and the right amount of money.
After May however... I don't want to think about it.
T.
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
