hi guys,
had 3 gauges put in today into centre console below single din head unit in a r33. before gauges were put in there was no engine noise or anything...really clear and great sound but after gauges went in there is the constant buzzing which increases as revs pick up but only through the front right tweeter. no other speakers just the front right tweeter. then started mucking around with it and if i turn the tweeter half a turn to the right it turns off then half turn to left turns back on like an on off switch...i have no idea.
what could it be? i'm lost because its only the tweeter and no other speaker? any ideas?
cheers
https://www.sau.com.au/forums/topic/154461-buzzing-noise/
hi guys,
cheers
Probably line interference.
The hard bit is working out where, tweeter cable is run to close to a main power, or possibly even a tacho line.
If you got it professionally installed take it back, tell em to fix their mistake, and they shouldn't charge you unless theyre dodgy.
EDIT: im dumb, rerouting of the gauges lines is whats needed, at least away from your tweeter wire.
Edited by infamous_t
https://www.sau.com.au/forums/topic/154461-buzzing-noise/#findComment-2877298
