hey lads. quick question.
im driving along put my foot down on high boost, you can hear the turbo whistleing away but theres just next to no pull at all, ill turn it to low boost half way through the gear and you can feel it kick in, but the turbo quietens down. 7psi low, 10 high
https://www.sau.com.au/forums/topic/154496-high-boost/
mate i got r33 gtst when it had standard turbo front mount and boost controller one of them $22 ebay ones everyone was going on about.. which was shithouese! i had more power on the standard boost then when i turned it up it ran like a pig all comes down to r&r and your standard ecu ...answer.. power fc and a tune :ninja:
my 2 cents!
https://www.sau.com.au/forums/topic/154496-high-boost/#findComment-2873444
i have had nothing to do with safc but.... i wouuld look into getting your ecu re mapped i dun know much about this but there has been alot of discution on these see what a search turns up... sorry i could not be more help. i am running a standard ecu (for now) frront mount pod turbo dump custom satinless one...full exhaust 11 psi before turbo went to slide for flowing wont be back in till end of month but it was running fairly sweet around the 10 psi mark.. but if you give it a boot full down low in the rev range its where it starts to run shit ease your foot on bringing revs up smoothly and it pulls like a train! sudden rush of air and your ecu has a heart attack R&R!
https://www.sau.com.au/forums/topic/154496-high-boost/#findComment-2884795
