Weird Question.. Chinese/asian/jap Shops In Vic? Where?
hello!
I've been looking everywhere in the city for an asian shop that sells chinese dresses and men's shirts etc.. in Sydney (where I grew up), there is a huge asian shop near central that has just about everything oriental you could ever need.. but down here I can't find anything! I even went to Vic Market but couldn't find anything there either (didn't help they were all packing up tho). Can someone point me in the right direction?
There's a very cool, expensive Hello Kitty shop in the city x2 but other than that I've only seen food supermarkets etc.
Northside or city is better.
I also can't find any Japanese shops that sell decorations, home stuff etc.. big fans, wall hangings and the like. Is there anywhere in Vic like that?
Also the closest Jap supermarket is in St Kilda even though we live northside.. if there is one closer please let me know! Too far to go for Dashi sauce.. might as well get takeaway..
I know where everything is in Sydney (helps that I grew up with a chinese stepmother).. but even after 6 years down here I'm still clueless (and I don't know where any shops are either!) :laugh:
Any help would be appreciated.. :)
Cheers!
Kaz
I wouldn't bother with Springvale as mentioned by a couple of people..... unless you're after asian groceries.
Some places that might be able to help you with stuff are:
http://www.shoji-tatami.com.au/
Asian Bazaar Imports
146 Ashley St Maidstone
any Ishka store
There are also a bunch of places that sell imported asian furniture and decor, but I only know of ones over in the south/south east.
In High st Northcote/Clifton Hill just before it goes wide at the bottom of the hill with the good city views.
There is a shop that sells imported asian furniture and sells cool kimono's and asian fabrics.
It might have some other traditional clothing?
There's one of Toorak rd half way between Chapel st, and Sth yarra train station.
And i've been told of one Burke rd, near the junction thats suppost to be good.
I'm trying to find Imported Asahi!! :laugh:
Have you tried Chinatown in the city?!? That would probably have everything you're looking for..... :P
well you'd think so.. but when I said I can only find supermarkets and mentioned the city, I meant chinatown basically.. there's a hello kitty/nightmare b4 xmas etc shop there.. but they have like maybe 3 dresses at a ridiculous price and that's it. :laugh:
Imported Asahi.. do u mean as opposed to locally brewed Asahi??
Michael used to work for Fosters and we were under the impression it was imported but maybe they brew it locally.. ?
Either way we get our Asahi from Liquorland or ColesOnline and Dan Murphy is a good place for rare drinks.. :P
Australian Asahi is brewed and imported from Thailand. The JDM Asahi taste's better, and i've been told the odd Japanese food importer sometimes has the odd slab or two thrown in the container when importing their main stock.
    • I think the concept is highlighting the various scenarios where thicker oil helps, and thicker oil potentially doesn't help and only generates heat and costs power, in turn for safety which isn't actually any safer (unless you're going real hot). If anything this does highlight why throwing Castrol 10w-60 for your track days is always a solid, safe bet.
    • Jason should have shown a real viscosity vs temp chart. All the grades have very little viscosity difference at full operating temperature.
    • Oops... I meant to include the connector  view... BR/W - power from fuse L/W - motor negative to fan control amp (and off to HVAC pin19) OR/B - PWM signal (from HVAC pin20) B --  ground
    • Yep, if you are applying filler it sounds like there is something wrong with the body lol. Safe to assume there is going to be a lot of sanding going on if your still applying fillers.  Picture a perfect bare metal panel, smooth as glass. You lay down your primer, it's perfect. (why are you going to sand it?) You lay down the colour and clear, it's perfect. No sanding at all took place and you've got a perfectly finished panel.  You won't be chasing your tail, sounds like you were prepping to start laying filler. If your happy with the body after the sanding, there is some bare metal exposed and some areas with primer, no issues at all, start laying the filler. You are safe to lay filler on bare metal or primer (of course check your technical data sheet as usual for what your filler is happy to adhere to).  This isn't a 100% correct statement. There is primer that is happy to adhere to smooth bare metal. There are fillers that are happy to adhere to smooth bare metal. Just make sure you're using the right materials for the job.  Typically if you are using filler, you would go primer, colour and clear. I've never seen any instances before where someone has laid colour over body filler (maybe this happens, but I haven't seen it before). So your plan sounds pretty normal to me.
    • I don't think there's any way someone is push starting this car.. I honestly can barely move it, and moving it and steering it is just flat out not possible. I'm sure it is, but needs a bigger man than me. I have a refurbished starter now. The starter man was quite clear and consise showing me how nothing inside a starter really should contribute to slow cranking, and turned out that for the most part... my starter was entirely fine. Still, some of the wear items were replaced and luckily it didn't show any signs of getting too hot, being unfit for use, etc. Which is 'good'. I also noticed the starter definitely sounded different, which is a bit odd considering nothing should have really changed there.... Removed and refit, and we'll pretend one of the manifold bolts didn't fully tighten up and is only "pretty" tight. GM only wants 18ft/lb anyway. I also found a way to properly get my analog wideband reading very slightly leaner than the serial wideband. There's Greg related reasons for this. The serial output is the absolute source of truth, but it is a total asshole to actually stay connected and needs a laptop. The analog input does not, and works with standalone datalogging. Previously the analog input read slightly richer, but if I am aiming at 12.7 I do not want one of the widebands to be saying 12.7 when the source of truth is 13.0. Now the source of truth will be 12.65 and the Analog Wideband will read 12.7. So when I tune to 12.7 it'll be ever so slightly safer. While messing with all of this and idling extensively I can confirm my car seems to restart better while hot now. I did add an old Skyline battery cable between the head and the body though, though now I really realise I should have chosen the frame. Maybe that's a future job. The internet would have you believe that this is caused by bad grounds. In finding out where my grounds actually were I found out the engine bay battery post actually goes to the engine, as well as a seperate one (from the post) to the body of the car. So now there's a third one making the Grounding Triangle which is now a thing. I also from extensive idling have this graph. Temperature (°C) Voltage (V) 85 1.59 80 1.74 75 1.94 70 2.1 65 2.33 60 2.56 55 2.78 50 2.98 45 3.23 40 3.51 35 3.75 30 4.00   Plotted it looks like this. Which is actually... pretty linear? I have not actually put the formula into HPTuners. I will have to re-engage brain and/or re-engage the people who wanted more data to magically do it for me. Tune should be good for the 30th!
