Well I got it last night after work.
First impressions are it's incredible.
It's beatiful to look at up close. The fit and finish is very good for a suzuki.
Not quite Yamaha, or Honda quality but they are getting there.
The stock exhaust sounds awesome! The best stocky i've ever heard, and it looks horn just like a motogp style exhaust.
The engine is still very tight i'm not supposed to go over 6000 revs to begin with. I went up to 7000 last night and wanted to keep going but i need to bed all the parts in before i start going balistic.
Damn it's a good bike.
So anyone that wants someone to go riding with just let me know.
But i'll still be coming to SAU south australian events.
Dad also got a new bike yesterday.
A new Yamaha FZ1.
It's an R1 engine from 2006 in a more upright semi naked bike.
The engine is tuned a little differently and has much more mid range than an R1.
It's pretty damn nice though, i went for a quick ride last night.
Thanks for the offer, but i love the flickabilitly of the 750 plus it has more than enough power for my skill level.
Makes me laugh when people equate cc of a bike to rider level skill. If your a noob on a 250, your a noob on a 1000cc.
Rider training is worth its weight in skin....gold...i meant gold :happy:
Not having a go at all...
I just dont agree with people who seem to think cc of a bike should = skill level. Look at the learners who are too physically big to ride 250cc for a first bike *Looks at Tangles* :kiss: (what was your first bike there?)
A 1000cc bike is no different to a smaller cc bike...except 2 things. Weight and revs...
Someone who isnt accustomed to riding (not yourself) would more likely get on a 600cc bike say, and ring the nuts off it thinking it wont be bad, because its only a mid size bike :happy:
Wish i had a dollar for all the noobs ive heard of getting on a mid size cc bike and doing 160 on the street in the flick of a wrist...yet they wouldnt jump on an R1 say and attempt the same, just cause its a 1000cc....
Well i have no problem jumping on any bike a ringing the neck off of it.
Like i said, the 600's lack torque down low, and i love the how well the 750 turns.
Like most magazines have said, it has almost the power of a litre bike and handles as well a 600. So that too me is a perfect bike.
Zx-14 is good for one thing... country miles.
The new ZX-6R just came in and looks great. I might have a test ride on it this weekend.
Bl4cK32 in regards to your earlier comment having a smaller bike i beleive does boost your confidents. On the 600's i've cracked the throatle coming out of corners and it's just powered out. Where as when i tried the same thing on a zx-10r on the same corner, it started to do a massive drift. And that affects ones confidence. It meant when riding i was more timid about opening the throttle right up.
This was about 3 years ago though.
Yer i agree with learning on smaller cc bikes, no arguments.
Its always good to progress to larger bikes. In fact SA should follow the other states with 250cc restrictions (2stroke racers - which i learnt on (and still own :D) then have another licence for say 600cc then above...
All should come with proper rider training, not the "sit on the bike with it turned off, and let someone push u across the range" that they do currently...
Well had my first hills ride and proper ride on the bike on Saturday.
And hell it was good fun.
I didn't feather my tires right to the edge, and my lines were all over the place. But it felt great to get back out there.
Now just need to get back into rythem.
  • 1 month later...
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
