Hey
I have noticed recently that these spray painted alien heads are popping up around the place. I kinda drew what they look like (see attached). They are usually spray painted in red and white or blue.
I have seen one painted on the wall next to Joy Garden restaurant on Francis St, another one painted on these rocks on Brookton Hwy Kelmscott, another one painted on a meter box on Churchmans brook rd Roleystone.
Has anyone else seen these anywhere? Does anyone know what they are and what they mean?? WHO THE PHUCK IS DOING THIS!! :)
Liz
There was some grumpiness articulated indeginous elders a few weeks ago in the West re: appropriation of sacred images.
Despite the scared meaning to the images owner(s), it was painted by "unauthorised" person(s) it has no significance and is therefore just more visual pollution.
Its pretty sad that the people resonsible obviously have no idea about the meaning of the image they are using.
All "taggers" should be hung by their testicles from the town gate....
I see one of these on the way to work every day on Alexander drive. There's a bend leading up to a set of lights (as you are heading in the direction of where it becomes Fitzgerald St) and on this bend is a small stone wall which is where the painting is. Also on Alexander drive there used to be one painted on a tree that was on the median strip but someone removed it.
I've also seen the one on the Kwinana Freeway.
Hey
Liz
I spotted one in Bentley when your heading towards the city ( On the right hand side of the road just after you pass the Bentley Shell Petrol station/subway ) its in a vacent block where people sometimes try and sell cars, you can see it from the road.
I think its a sign....
They will be back to abduct me again soon..
also seen it near one of the walkovers on the kwinana freeway near labachoure road
Yer como overpass. First time i saw that i got some serious shivers, i dont like em, they freak me out big time.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
