Hey guys i just purchased a power fc with hand controller.
The pfc has a tune that was done by hitman on a r33 with the same mods as mine.
I tested it and the max knock i could get floggin it at 10pm tonight was 25. It only got 25 onlce, mostly would be arounfd 14-18 knock.
Going by this ruff diagnosis will this tune be fine for me to use for 5 weeks till i can afford a decent tune if i monitor knock?
I plan to wait till i buy a turbo then get the whole lot tuned.
Thanks in advance guys
Edited by tmc_2
https://www.sau.com.au/forums/topic/154598-power-fc/
If you just drive it sedately, there is no reason why it wont be ok.
If its not knocking then thats not too bad
I wouldnt go flogging it though. I would have it all checked with some AFR's aswell as Risking said.
Might only require a touch up, or maybe nothing at all and it'll cost you basically a couple power runs ($80)
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875659
Thanks for the info guys,
I was of the assumtion that if it had low knock and the car sounded and felt right it should be ok? If the Air/fuel was lean wouldnt that cause a knock reading?
What if i erased the tune and ran the base maps? would htat be any safer?
I might enquire about gettgin it checked tomorrow, jsut dont wanna spend money as trying to save for a turbo then get it tuned.
Cheers
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875674
Just drive it sedately... then it will be safe, just like the base map :laugh:
If you dont wanna spend the coin for a few weeks or whatever.
I would suspect it would only be a mild touch-up to the map anyhow.
There are other factors, but that doesnt matter for what we are talking about.
If you just put some self restraint on your right foot...
Thats all the safety you need, either that or put the stock ECU back into it and go back to how it was :sorcerer:
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875679
Thanks for helpnig me clear that up, i will se how i go gettign it checked for cheap :)
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875681
Id recommend you be putting the stock ECU back in. Unless you can keep off the right foot.
Lean AFR's have nothing to do with the knock readings unless you are pysically out of flow and its really leaning out big time.
My GTR was maxing out the injectors at 1 bar. Run 1.1 bar and it would detonate. Put in a set of 800's and countered for them with the Same ignition map and no more knocking.
If you drive it around leave the Tune in there that it currently has.
Just get a few power runs done and some light throttle cruising checks.
Edited by Risking
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875685
The only shop tomorrow likley to take me charges 120p/h dyno time and their labour is $75p/h , not cheap. So i will quiz them about checking it.
Ideally i will be taking it some where else, but that some where else needs to be booked in advance, theire time is gold but well worth it.
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875689
If your in Sydney, we are having a Dyno Day at J.E.M in Moorebank for $50 and will tell you AFR, Detonation, Max Power and the tuner will let you know if you need a tune... otherwise we have a G.B for $450 you get a FULL Road & Dyno tune with print out...
Cheers
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875728
Cheers
Hi i am located in brisbane guys.
thanks any ways
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875736
    • Only needed to pull out the seats, center console and gear shifter surround, took a weekend and a fair few beers. You get to look forward to finding all sorts of weird shit under the seats and carpet, I pulled out a Chinese dudes passport from 2003, 220 yen and a condom wrapper 😆
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
