Hey guys i just purchased a power fc with hand controller.
The pfc has a tune that was done by hitman on a r33 with the same mods as mine.
I tested it and the max knock i could get floggin it at 10pm tonight was 25. It only got 25 onlce, mostly would be arounfd 14-18 knock.
Going by this ruff diagnosis will this tune be fine for me to use for 5 weeks till i can afford a decent tune if i monitor knock?
I plan to wait till i buy a turbo then get the whole lot tuned.
Thanks in advance guys
Edited by tmc_2
https://www.sau.com.au/forums/topic/154598-power-fc/
If you just drive it sedately, there is no reason why it wont be ok.
If its not knocking then thats not too bad
I wouldnt go flogging it though. I would have it all checked with some AFR's aswell as Risking said.
Might only require a touch up, or maybe nothing at all and it'll cost you basically a couple power runs ($80)
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875659
Thanks for the info guys,
I was of the assumtion that if it had low knock and the car sounded and felt right it should be ok? If the Air/fuel was lean wouldnt that cause a knock reading?
What if i erased the tune and ran the base maps? would htat be any safer?
I might enquire about gettgin it checked tomorrow, jsut dont wanna spend money as trying to save for a turbo then get it tuned.
Cheers
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875674
Just drive it sedately... then it will be safe, just like the base map :laugh:
If you dont wanna spend the coin for a few weeks or whatever.
I would suspect it would only be a mild touch-up to the map anyhow.
There are other factors, but that doesnt matter for what we are talking about.
If you just put some self restraint on your right foot...
Thats all the safety you need, either that or put the stock ECU back into it and go back to how it was :sorcerer:
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875679
Thanks for helpnig me clear that up, i will se how i go gettign it checked for cheap :)
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875681
Id recommend you be putting the stock ECU back in. Unless you can keep off the right foot.
Lean AFR's have nothing to do with the knock readings unless you are pysically out of flow and its really leaning out big time.
My GTR was maxing out the injectors at 1 bar. Run 1.1 bar and it would detonate. Put in a set of 800's and countered for them with the Same ignition map and no more knocking.
If you drive it around leave the Tune in there that it currently has.
Just get a few power runs done and some light throttle cruising checks.
Edited by Risking
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875685
The only shop tomorrow likley to take me charges 120p/h dyno time and their labour is $75p/h , not cheap. So i will quiz them about checking it.
Ideally i will be taking it some where else, but that some where else needs to be booked in advance, theire time is gold but well worth it.
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875689
If your in Sydney, we are having a Dyno Day at J.E.M in Moorebank for $50 and will tell you AFR, Detonation, Max Power and the tuner will let you know if you need a tune... otherwise we have a G.B for $450 you get a FULL Road & Dyno tune with print out...
Cheers
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875728
Cheers
Hi i am located in brisbane guys.
thanks any ways
https://www.sau.com.au/forums/topic/154598-power-fc/#findComment-2875736
