doesn't look too bad at all. Would do wonders for stock plumbing on a Standard Skyline
Yes I ran one similiar on my 25, just the FMIC's slates that allow the air to run through where perpendicular to that of yours. Worked just fine, 277whp on stock turbo at 11psi, lag from going to that from a side mount was unnoticeable.
My younger brother had one on his r33 also. A PWR variety. For ease of installation and piping fab, it was pretty good with little modification required. However they bend into a nice 'U' shape when you hit a tree at about 80kph.
I have an Apexi Genuine equivalent....made 240 rwkw on it before i sold the car.
Its for sale in the classified section if your interested.
it would be ok as long as there was some kind of separator plate in the end tank between the entry/exit holes
essentially it would be 2 thin intercoolers on top of eachother...
but if there were no separating plate, theoretically most air would bypass the core and go straight to the engine without going through the core.. that would obviously be pointless
cut it open see if there is a separating plate in the middle :)
you'd be able to see the separator plate from looking in the ends with a torch.
This intercooler would be excellent. The air spends a lot more time in the intercooler than a normal 600 x 300 x 75 mm one.
I could see another benefit with that particular Ebay intercooler is that it wouldn't completely block the radiator. But would it provide decent cooling or is it not worth it?
air only goes in the direction you point it and doesnt like changing directions and a tight 180deg turn will definetly have an impact on flow characteristics
the kits that have the return pipe over the top of intercooler are quite good to save a bit of pipework hassle , thats 2 x 90 deg turns instead
having said that these type of coolers can still perform ok and obviously an upgrade from stock
Edited by arkon
dont cut it, im sure there wld be a seperating plate - its like two small intercoolers sitting on top of each other, with a u-tube connected at one end.
Edited by Trav33
currently have 1 on my car thought mines of the standard core size with a curved style end tank on the left.
the flow is not as bad as you would believe, the pipping on mine was a nightmare as the top side pipe is to high and requires an extra bend,almost immediatly to get low enough to get past the reo and into the corner of the car. its an excellent method of dropping excess pipping and even allows use of hte stock piping route.
down side is you have a wierd looking FMIC setup, having hte piping on 1 side means you can see the usual pipe on 1 side but not the other and the fact that mine has a curved side which improves airflow back looks wierd when you can see it behind hte front bar.
i had a trust version of that cooler on my R33, mad 244rwkw no problem, If you look closely it is actually two coolers side by side, with the fins pointing up and down rather than left to right..
It is in the for sale section if anyone is interested.
    • And also there were for sale scams and the like. For sale posts need piccies, and not having piccies makes it harder to do a driveby scam.
    • And I forgot to add my *** footnote to the above post, which was that the pipework mods would be even more significant than what had to be done for the highflow. So just add that onto the list. Pipework mods are no killer, just made the tasklist longer at a time when extra tasks were not welcome.
    • I mean he could post them to imgur or the like and create a link. But yeah, spam bots absolutely will post pictures in their first posts.
    • Ah ok, reason I asked was for the sake of not having to upgrade everything if the turbo couldn't be capped.
    • pffft! My alignments are starting to take 3-4 weeks each. Bugger overnight - that would be a dream! Overnight is when I leave it on stands with the rear suspension in pieces, hoping I can remember where I was at when I come back to it. I have to set the car up on a level surface so I can get decent camber measurements, then try to set the RUCAs to the right length to get that right. Then I have to put the car somewhere else where I have enough room to set up the bumpsteer gauge (laser, paper, mirror), so I can dial out that. Then I need to go measure camber again because changing the tension arm length affects that also. Then I need to measure toe, and I can't do that to my own satisfaction at home, so I have to put it on an actual aligner. Then I have to go back and fix the camber again, and if that took more than a half a turn, decide if I want to set up the bumpsteer measurements again. I previously had the bumpsteer almost completely banished and then I started changing things again! And that's only the rear end. Not even gotten to talking about the front yet. And this has been going on in the context of me discovering a seized bolt in the LHR FUCA bush at the upright, hence needing total disassembly to replace that bush and the others that were not far away from the same outcome, replacing sphericals in the front end and making a mistake that resulted in needing to do it again, which is only half done right now. It's a selfmade nightmare. Only have self to blame, etc etc. But regardless, I am so complelely unable to utilise the services of a normal wheel aligner that I have no choice. I haven't found a shop in my city that does "race" alignments - and by that I don't mean I want my car to be set up for racing, but the set of adjustments that I have available and that need to be used to do the alignment are the same as you'd find on a race car. I haven't looked everywhere, but there doesn't appear to be the equivalent of the motorsport focused shops that are present in Sydney and Melbourne. And such an alignment would cost $300, and you only want to do it once in a while, and you don't want to find out that you have to replace bushes and bearings and such while you are spending that $300 so you have to come back and spend it again a week later. So I stay living in my self made nightmare for the moment.
