So i have finally decided to get a new oxygen sensor form Mr Nissan, but my problem is that its bloody impossible to remove as i can't get a spanner in there and get enough torque on the spanner to undo it!
i tried an ultratune which was open sat mornings that is nearby me, but they don't have the tool to do it :(
now i know there is a tool which is like a big socket that goes over the o2 sensor but has a hole in the side for the wire to go through.. i went to supercheap and repco but no luck. repco have one in toowoomba but that's not much help
this is what it looks like:
http://cgi.ebay.com/ebaymotors/Oxygen-Sens...sspagenameZWD1V
so does anyone have one?
or does anyone have another special device that could help me out?
a 6-pack of beer is in it for any kind soul that wants to help me out this weekend
preferrable near to the brisbane city
cheers,
Warren
PS if you can help me out, send me a PM with your mobile/home number so that i can contact you :woot:
https://www.sau.com.au/forums/topic/154630-oxygen-sensor-removal-tool/
would a ring spanner fit in there? undo the clip and put the wire through the ring spanner hole??? although the clip might be too big to fit through the ring spanner... give it a try anyway
i use a ring spanner with a piece chopped out of it
drive it around here :D
Get out the WD40 and crc, also ever tried a 12" shifter and a hammer to break rust. usually works for me, there easy to get off dun see the problem.
Mind you if you were to be travelling down as far as springwood way i would do it for free
PM sent
I have always used an adjustable spanner for the 02 sensor and have always found them to be just over finger tight...
When you put the new one in just pinch it up just over finger tight again, they dont need to be done up to 100lbs with a torque wrench... :)
must say the O2 sensor was one SOB to get out, just ask warren, the thing was on so friggen tight it wasnt funny, let alone there wasnt much room at all to get to it, but all in all supercheap came in handy, and finally got it out with a 22mm long socket, Perfect fit all round, as long as you do not require your old 02 sensor, and in with the NEW one with 1/16 to 1/8th of a turn after hand tight, perfecto.
Cheers and glad to help
Adam
Splash of brake fluid and a decent open end spanner never let me down.
Has the change of O2 sensor made your car feel any better in closed loop mode Warren?
I noticed it struggled to climb revs slowly when just touching the throttle but when you just started to back off the revs would jump then fall. Usually an indication of O2 sensor malfunction.
thansk again adam, hope those beers go down nicely >_<
daniel: haven't been able to notice much difference yet as i have only driven it home and nowhere else. but, it hasnt missed a beat yet
i will report back of the differences in a few days.. and with some fuel economy changes (if any)
oh, and i have had a couple of PM's about the part number for the geniune nissan item, and its: 22690-73L11
    • A locally delivered Infiniti have remote start installed but don't come with the remote start key. You need a new remote start key and they just need it programed. And this is different to making/programing a new key that just starts the car.
    • Cheers, and cheers for sharing so much of the build and also sharing the glimpse of what turns out to bring a lot of us poor decision makers together haha.  I do recommend learning more about how to manage it, if not considering getting a  formal diagnosis.  The discussion with the psychiatrist I got my diagnosis through was quite eye opening, things I'd not even considered to be ADHD related and hadn't mentioned were things she asked about out of the blue and were common themes with people with my flavour of ADHD.   It's not a label for people who are hyperactive and ill-attentive, there's more to it than that and some of it can be much more challenging or damaging - though there are of course two sides to the thing, and a lot of the stuff we have to go through and work on to live with it make us effectively "better" at other things as well. Aside from the fact that there is some argument I could have a bit of ASD seasoning in there (came up during the diagnosis, and neurodiverse things seem to not stay as a cookie cut) I suspect you need to learn more about ADHD if you are puzzled about how hyperfocus could possibly apply.  I *do* personally use "superpower" with quotes deliberately, but it's 100% an ADHD thing due to the exact reason that lack of focus is also an ADHD thing... Loosely speaking the inattentive side of ADHD isn't the inability to focus, it's the inability to control where the focus goes.  Not being able to sleep because brain is more interested in thinking about a stupid thing I said to a girl I liked 30 years ago, not being able to focus on work because my brain is more keen on putting together the torque management strategy we're going to try out with a drag car next weekend, not being able to focus on a conversation with someone I WANT to listen to and respect because there is a flickering light in my peripheral vision.    If I could just stop work and build the torque management setup right there and then I'd not hear anything else until it was done.
    • Maybe you should do some more reading.  Google positive effects of ADHD and you'll get your answers.  One of my personal downsides of ADHD has been talking before I think.   Maybe you have it too?
    • Excuse me for butting in....but which part of ADHD can be considered a superpower? I would have though it far more likely that some ASD comorbidity is more likely to be contributing to an ability to hyperfocus on something. ADHD being aimed somewhat in the other direction. My shed looks like your shed. My whiteboard list of unfinished projects has entries going back 15 years. I know what you're talking about - I just struggle to connect ADHD to the results being discussed.
    • Thanks for reaching out!  It's a blessing and a curse at the same time.  I'm undiagnosed but it doesn't take a rocket scientist to see it in me... I have more half started projects laying around my house, shed, garden, etc taking up space and money, destroying aesthetics than if I added up all of my mates projects together. But, ADHD gives me the ability to hyper focus on things that no mere mortal could even  comprehend.  A recent pool build is an example of that....  I dont know anyone else that would be dumb enough and focused enough to take on then complete something of that magnitude. I call ADHD a superpower but it can equally be completely destructive if not controlled and focusedon the right places. Addiction is a major concern to ADHD people and thankfully my addictions have been no worse than projects, XBOX, chocolate and being an arsehole! It's often hereditary and my 13 year old son is currently learning how to drive it at the moment. Keep lurking! If i can finally finish this bloody thing at some point it will be a win for all of us ADHD'ers! 🤪
