Nah we should be right, i have a friend who is 99% gonna come, he is on here as well but dont know his nick. Do you guys prefer to keep it at 8ppl and pay an extra $25? Cause it seems like it would be more worthwhile for us. If nobody objects then I will limit the number to just 8 then so we get more track time.
uote name='StinkyPoo' date='15 Mar 2007, 11:59 PM' post='2982380']
I would love to go.. I might, but it's kinda tight with timing. Gibson Motorsport will be running their cars out at wakefield on the same day(they're look and SOUND freaking awesome!). Plus i've got gokarting with another club, ARGH!!!
Oh yeh, I probably need to get those rims back off you CEF11E. I'll need them for a drift day at easter weekend.
  • Replies 77
Posted Images
OK guys so we are now confirmed for the 31st of March. All ppl attending will be required to pay an extra $26 on the day to make it a total of $125. Please reply or PM if you are NOT ok with this.
Make sure you turn up with good tyre pressures and a fullish tank of gas.. starting time to be confirmed.. i think its 8.30 or 9am.
Question 1: What tyre preasure do people normally run for these i would imagine either normal street level or slightly more ???
Question 2: The ground is wet right so it won't wear the tyres down to much ??? if so i will probably just put a set of my stock 33 tyres in.
1. I think most people just run the normal street tyre pressure.
2. The track is wet in parts, but if you slide out or spin around on the outside, you do hear the joy of your rear tyres dragging themselves along the dry slightly uneven concrete. If you start going regularly though you might want to put some track rims on the rear.
Yeah I usually run 38psi on the street, Derek recommends tyre pressures slightly higher than what most ppl run on the street which would be 32psi.
If you have a cheaper set of rims I would put them on the rear. Tyre wear is quite minimal really unless you spin out alot or take the dry lines as CeJay mentioned, but I would still rather wear out my stockies than my 19s!
last time we had 8 people we all got 3 x 20 min runs and a 5 min run at the end :P
Good Times!
Here's a tip :):
check the level of your power steering fluid before you go and make sure it is topped up. Also take an old sock with you and cover the power steering fluid canister as it usually over flows a bit. Also full boost is not needed. i turn the boost right down to give the car a bit of a break.
Well at the moment I'm still in on this, but what turned from getting my car back monday/Tuesday this week from the smash repairers has blown out to this friday..... At the moment I'm not sure if i'll take the car out even if it's ready due to the paint. But either way I'll show up. Damn I'm in a shitty mood right now. :dry:
Anyways, thought I'd let everyone know, there "might" be a camera guy or two at the drift day, trying to get better at their techniques etc. So be on the lookout if they showup, might be able to get some footage of your car.
I also have a car but no wheels at the stage...
new ones coming from brisbane via horse and cart. I will be spotted at revolve digging thru scrap piles looking for some 4 x 114.3 dorifto rims.
Woo Hoo I would like to see a skyline riding on fat 14'z yo...
I will be there and drifting even if I have to make some damn wheels...
Sorry I didn't get back to you earlier bout this Paragon, was just in a panic about trying to get the new car, but I'll be there to watch ;)
BTW cef11e, I got some r31 silo rims if you want to borrow them
seems like i am in the same fix as you two guys put together. I am picking up my car from J Racing tomorrow afternoon.. hopefully and i have no rims. The rims i have i cant get an appropriate hub ring locator for and so have been advised not to use them on track. Does anyone have a pair of R33 or S15/14 5x114.3 stockies I can borrow? PM me or get me on 0414 610 499 PLEASE!!!
    • Hi all. Been a while but things are moving along. I just have something that I am wondering about. Since I will use OEM turbo oil pumbing, I got myself a new bolt, the one that goes into the engine block oil feed. As I recall (and see visually) this bolt comes restricted with I think a 1.7mm hole? Not quite sure but it was something around that size. The turbos have 1mm restrictor bolts installed, as necessary due to ball bearings and my higher oil pressures. Can I now just use that OEM bolt with the 1.7mm hole in for the engine block or will this actually be too much oil flow restriction and I have to drill it out first? In my head it would make sense for the bolt to be at least 2mm wide as both turbos take "1mm of oil flow". Do let me know if my logic is flawed here, I just want to make sure I don't kill my turbo bearings with too little oil. Don't know if I can trust the saying I read somewhere that ball bearing turbos essentially only need an oil mist
    • There are several aftermarket options available, from not-too-painful moneyhttps://justjap.com/collections/driveshafts-bearings/products/d-max-reinforced-replacement-rear-driveshaft-set-fits-nissan-s13-s14-s15-r32-r33-r34-c35 and  https://justjap.com/products/crank-motorsport-billet-rear-axles-fits-nissan-skyline-r33-gts-t-r34-gt-t?srsltid=AfmBOorQk4xkGUa98kO7v2ePLUiNt-HRrM2AwWNw9mbSIVE1ujBVwY__, all the way up to The Driveshaft Shop https://driveshaftshop.com/skyline-cv-axles/
    • Yeah based on old XRC5964S specs, it looks to be roughly GTX3576R sized? But this 5964S compressor will flow 90lb airflow somewhat similar to the compressors in both the GTX3584RS or G35-1050.. I fully expected the 0.64 rear A/R to choke up top - seems way too small from typical convention - but these are seemingly beneficial over the prior 0.82 results.. Be interesting to see if he comments on the EFR question in that thread - he mentioned in a prior video that BW EFR's were the "cats pajamas 10 years ago", but by the sounds of things all his kits have been using Xona for quite a while now.
    • Yeah it’s still got the oem manual gearbox and clutch, only kinda mods are a blow off valve, coil overs, and a aftermarket intercooler. Also had it for about 2 months now with a lovely midnight purple paint on it.
    • Yeeeppp, been following a lot of the testing on the latest Xona stuff and there are some mental results.  He also went over 1000hp @ 4 hubs on his Mainline with a XRE6364S (63mm) which was also well into the 20psi range before 4000rpm on a 2.5. Crazy stuff. Fwiw the XRE5964S is basically the modern equivalent of their old HTA3582 - would drive nicely enough on an RB25 or 26, but proven capable of a huge amount of power if you want to spicy with rpm tho even at sane boost levels will make stout numbers
