Hey all,
A member of SAU sent me some photos of a GTT with a rather unique paint job mod on its front bar, making the grille look larger than it actually is (no more slope). I sent these photos to Mitch and we decided it'd be worth doing :D
Items Needed:
1 x Can of Satin Black Spray Paint (from SuperCheap Auto $2.99)
1 x Series of Sand Paper (lying around)
1 x Old Painting Sheet
1 x Roll of Masking Tape
Process:
Mask up your area to be painted with the tape and then proceed to cover up all surrounding areas with a combination of masking tape and the sheet. We tore a hole in the sheet to provide a better painting area and coverage (please note you can susbtitute the sheet with newspaper)
Sand the clear coat of your original paint back so you get a nice smooth matte finish... This will provide a "rough" surface for the paint to adhere to. Remember to look at the area from various angles just in case you missed a spot. Clean the area up from paint dust and crap with some Wax & Grease remover.
Shake can of paint up for 5 minutes (vigorously, none of this girly shit)
Using sideways strokes, apply the paint one layer at a time... it does not matter if you first coat leaves it looking very cloudy, the other coats will cover it up later. Allow to dry for 10minutes and repeat until you are satisfied with the finish.
Note that the satin black paint will apply with a "gloss" but will go matte when it drys...
END RESULT:
A before shot for comparison (dont mind the eye-lids :))
And after:
And the money shot:
Comments? I think it looks very nice... doesn't cost much to do and gives the entire front end another perspective!
https://www.sau.com.au/forums/topic/154687-got-bored-did-some-diy-painting/
LOL awesome!!!! You don't waste any time do ya!????? Exactly how I was gonna do it, just wanted you to be the guinea pig first ! :) Hope you're happy with it! Will give it a go when I get the chance.
Do you have any pics of how you masked all the surrounding areas??
Such a subtle change, but a noticable one!
I've got the nissan sports aero frontbar, I'm thinking of painting the "skyline" in silver. Anybody tried this?
yeah i got the aero kit as well and been thinkin of painting the "skyline as well".. not sure what colour but... maybe black haahaahahahahaha.. juz kiddin.. has anyone done this b4? an if u have has the paint come off after a while?
I used brake caliper paint on my previous R33 to paint the "skyline" letters on the rear garnish the same colour red as my brakes. Turned out schmick & didn't crack or fade one bit.
I'm gonna try painting the "skyline" on the front bar on my day off next week. I'll either use the silver I've got lying around already, or white. If it turns out shite I can always paint it black again :laugh:
I'm gonna try painting the "skyline" on the front bar on my day off next week. I'll either use the silver I've got lying around already, or white. If it turns out shite I can always paint it black again :P
yeah good point if its sh!t u can always og over it in black again... take some pics once ur done i wanna c how it turns out..
another question... since that part of the front bar is matt black has anyone used things like armourall to make it a bit glossy? is there better things then armourall to use?
  • 3 weeks later...
    • I mean this in no disrespect to u mate; Are there clear tagged examples/explanations in our SAU forum for example, in my interest, this is how to do R34 Gtt suspension the right way? U guys did so much taking risks with experimentation that deserves recognition and those results helps us morons take the RIGHT path to buy quality / buy once. 🍻
    • Pretty much what you'd expect at that power level. Hypergear turbo, long list of supporting mods, full Haltech catalogue, etc.  I'd say this goes for most drivers, suspension is still a dark art for most people. And it's really hard to convince someone how much better their setup could be...
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
