tmc_2 Posted February 3, 2007 Share Posted February 3, 2007 Hi guys, I took my car to get the air/fuel ratios checked out on the dyno and the PFC checked today. Turns out i have a "walking CAS?" they say thing the backing plate the CAS bolts to is loose some how so my timming is changing every now and then, even though visiually it is bolted and doesnt move. Has any one experienced this or know why or what is involved in fixing it? Thanks Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/ Share on other sites More sharing options...
dontfeelcold Posted February 3, 2007 Share Posted February 3, 2007 Do the bolts up that hold down the cas bracket? Could be components, like the half moon key thing. Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-2877482 Share on other sites More sharing options...
tmc_2 Posted February 4, 2007 Author Share Posted February 4, 2007 The half moon on the CAS is fine, and the 3 bolts you can see are secured. Im yet to see what the bracket inside looks like. Has any one had this before? Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-2877821 Share on other sites More sharing options...
dead32 Posted February 4, 2007 Share Posted February 4, 2007 nope never had it moove. theres an alloy braket that the cas bolts 2. the retainer bolts for that are under the timming cover. do you have adjustable cam gears? <<possible cause also there could be interference with the crank angle sensor causing it to skip. Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-2877869 Share on other sites More sharing options...
tmc_2 Posted February 4, 2007 Author Share Posted February 4, 2007 nope never had it moove. theres an alloy braket that the cas bolts 2. the retainer bolts for that are under the timming cover. do you have adjustable cam gears? <<possible cause also there could be interference with the crank angle sensor causing it to skip. Is it possible if the bracket bolts where loose ths would cause it to walk? I dont have adjustable cam gears. By the way on the PFC at idle my base ignition is on 15 and is fine doesnt wander??? when i visually look at my CAS its bolted in the way advaced position. Tuiner told me they didnt wanna tune it till they get the CAS issue sorted but i dont see the problem they are talking about? Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-2878523 Share on other sites More sharing options...
Bl4cK32 Posted February 4, 2007 Share Posted February 4, 2007 My cas was farked at one point. It would hold timing nicely then once on boost loose power. Turned out the cas was farked, and once it hit boost it would just pull all the timing out, hence not making power. Cas was fixed and was fine Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-2878542 Share on other sites More sharing options...
Spoolup Posted February 4, 2007 Share Posted February 4, 2007 I have experienced this same thing, went from 15 degrees base timing to 0 degrees, which could have been disasterious if it had of went the other way. Are you using the std cam gear cover or is it removed ? Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-2878584 Share on other sites More sharing options...
Adriano Posted February 4, 2007 Share Posted February 4, 2007 My cas was farked at one point.It would hold timing nicely then once on boost loose power. Turned out the cas was farked, and once it hit boost it would just pull all the timing out, hence not making power. Cas was fixed and was fine Yep, my 300zx did that, i dont see how the bracket being loose(scary) would cause the timing to change enough to notice, unless the bolts were completely undone, as the bracket is located to the head by dowels, if they are that loose, your timing is the least of your worries. Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-2878593 Share on other sites More sharing options...
tmc_2 Posted February 4, 2007 Author Share Posted February 4, 2007 Thats really interesting guys, i had a think about it and yes even ith the bracket was loose i done see it effecting timming much. So could this be a sympton of fualty CAS itself? Ive been watching base timming on the PFC handcontroller. It says 15 at idle, now visually the cas in in extreme advance position? does the PFC over ride the physical possition of the CAS and change base timming to what ever its set to? I might buy a second hand CAS and see how that goes? what do people think? Thanks guys Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-2879142 Share on other sites More sharing options...
gt-t_r34 Posted July 9, 2007 Share Posted July 9, 2007 ive got adjustable cams and ive had problems with timing ever since i got them in my CAS screws were loose the other day and timing was all f**ked up. its all fixed now i just keep watchin the screws makin sure there tight Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-3220833 Share on other sites More sharing options...
shanef Posted July 9, 2007 Share Posted July 9, 2007 loctite the suckers maybe? Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-3220947 Share on other sites More sharing options...
MANWHORE Posted July 9, 2007 Share Posted July 9, 2007 I'm actually trying to diagnose the same problem. Using my consult screen, my timing is jumping on idle. I'm going to try and clean up my idle first. I haven't cleaned all the valves etc - that could be a start - cold start valve, aac etc. Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-3221086 Share on other sites More sharing options...
AdamsR33 Posted July 10, 2007 Share Posted July 10, 2007 The PFC is only assuming the base timing is set at 15deg, you could set it to what ever you want so long as you set the pfc the sameway, eg: say you set the base timing for 20deg but in the pfc its set at 15deg, the pfc assumes its 15deg, it doesn't read what it actually is. so if base timing is 15deg, then you have to set the pfc to 15deg. if its 20deg set the pfc to 20deg, etc etc do you get what i'm trying to say? Link to comment https://www.sau.com.au/forums/topic/154696-cas-walking/#findComment-3221501 Share on other sites More sharing options...
