iv had an r33 gtst for about 6mnts and now am wanting to modify my engine. the only modifications are intercooler and pod filter that i noe of. i hav $10000 to spend and was wondering if anyone had any advice on modifcations to get the most power from my engine. i hav in mind to put in a computer, new fuel pump and injectors. also will be purchasing a new turbokit with a bigger high mount turbo. are these mods wise? Also thinkin bout converting the rb25 to a rb30 block is there ne great advantage to this or is it just alot of hassel for only a minimal advantage? Ne advice would be much appreciated.
https://www.sau.com.au/forums/topic/154697-engine-upgrade/
if i had 10g large to spend and was happy how my car looked
id go, nice new suspension
brake upgrade
hiflo stock turbo
injector upgrade
powerfc
fuel pump
z32 afm
exhaust, dump pipe, hiflo cat
and get a quality tune
i would make sure to buy as quality parts at the 10g allowed
https://www.sau.com.au/forums/topic/154697-engine-upgrade/#findComment-2877266
It comes down to what you want to do with the car.
Personally, i want a car with good response at the expense of top end (even though i have fluked a good balance) as my car is predominantly street driven.
With that in mind, I dont think you can go past a garrett 3071IW (or 52 trim 3076 IW if you want more then 270rwkw) on the stock manifold, with dump and lines and intake pipe installed should be under 3k. You're at the limit of your stock internals already.
Id get hks 256/264 cams for about 1200 delivered, add 300 installed.
z32 afm and pfc (if you can find one) 2k installed and tuned.
5 inch metal cat and cheapy exhaust and front pipe from someone like just jap say 1200 installed.
555 nismo injectors, say 1k installed if you get your own off nengun or perfect run and have them installed with the rest of the gear.
The remaining 1k or so on swaybars and upgraded springs and shocks.
There's a lot more suspension and driveline stuff you will need to do later on to get all the power down but your out of cash for now :)
https://www.sau.com.au/forums/topic/154697-engine-upgrade/#findComment-2877319
id go, nice new suspension - 1500
brake upgrade - 1000
hiflo stock turbo -2000
injector upgrade - 750
powerfc - 1000
fuel pump - 300
z32 afm - 350
exhaust, dump pipe, hiflo cat - 1200
and get a quality tune - 500
I concur once again :)
I've added in some rough prices into the quote above...
It works out to around $8,600 not including labour which will makeup the $1,400 once it all in/fitted etc etc.
However a crucial point, i'd also add a clutch to the list $1,200... so total will probably be closer to 11k give or take
The car will be much faster with the money spent on important areas like suspension/braking.
It will also be much more fun to drive than something with just outright power and absolutely no way to use it.
I see little point in spending just 10k on the motor alone for big turbos/manifolds/3ltr bottom end as its totally out of the price range. Its closer to around 20k by the time you do it all if you want the handling with it.
You could "just" spend the 10k on all the power, make 300rwkw, but the car next to you with 250rwkw will give you an absolute hiding anytime, anywhere.
Being it will have a good lot of parts that make a fast car, not just a banger motor.
Power does not automatically equal a fast car, it an overall package. And for the street, 250rwkw is about as much as you'll need
So loser1, take the advice or not, thats just my personal opinion after being around for a few years :P
https://www.sau.com.au/forums/topic/154697-engine-upgrade/#findComment-2877683
I agree. Too much talk of 300rwkw and not enough of a decent car thats going to go the distnace and be able to dirve well.
eg decent suspension upgrade will cost you 3k installed. Bilstiens, spings, swaybars, bushes etc plus install.
Clutch as mentioned...for 250 or so there are plently of options. about 1-3 k installed depending on ur option.
5k of those alone which doesn't make power...just allows ur car to use what power u just made.
https://www.sau.com.au/forums/topic/154697-engine-upgrade/#findComment-2877909
thanx guys for ur input i appreciate it it helps but i already hav sway bars, brand new adjustable coil overs, aftermart 3" straight through exhaust so handling and suspension is not an issue this is about power gain. I will make any adjustments later if neccessary. The turbo has already been rebuilt with a larger compressor wheel. I hav ova 200rwkw im jus lookin for the 300 mark or over. and the clutch will be changes cause its stuffed.
https://www.sau.com.au/forums/topic/154697-engine-upgrade/#findComment-2882032
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
