Cheap Run About
@GTSBoymmanual I should have specified
@GTSBoySorry na 34 box and 33 turbo box I ment
@GTSBoy totally unrelated but I am unable to message you privately. Do yoy know if the r33 turbobox and r33 na box have the same tailshaft yoke? Can I use a 34 na shaft in a 33 turbo box?
By GabsReDeal · Posted
It seems that after 3 days of usage, it started missing again on one cylinder. Then eventually stopped missing but was stalling after a few minutes. The spark plugs, injectors, and fuel pump are all alright. So I am considering the tune might be wrong. Weirdly enough though, it took 3 days of running perfectly for it to start giving issues. Just an FYI, the fuel pump which is stock is constantly 3 Bar (43.5 psi). So you were absolutely spot on. -
3 litre out just need to win lotto and slap a 3.2 into it
