Just wondering if anyone here would know
What is the quickest R31 Skyline in australia - street legal- or close too.
Especially powered by a RB30ET.
Reason is had reports from a member on here ages ago that iwas about 10.5 don't knwo the mile. but if so A associate is planning to run at least a low 10 so looking for something to AIM at :)
Thanks
https://www.sau.com.au/forums/topic/154704-quickest-r31-skyline-rb30-powered/
Hate to spoil the party, but if you go to this link you can read all about an RB30 powered R30 doing 11.5 @ 124mph on STREET rubber
http://nissanking.sphosting.com/r30/history.html
Cheers, D
Cheers, D
this is the same car as in Ghostrider's link but before the twin cam conversion
http://nissanking.sphosting.com/r30/index.html
i have'nt read about any street legal 10 sec r31's let alone running rb30et, there are a few VL's running in the 10's that are street cars..
most r31 guys just bolt the turbo gear to thier N/A blocks rather than whole VLT engine swaps
99% of us are poor and can't afford to put the $$$ into just the engine let alone what else is needed for 10 sec slips...
Edited by rsx84
mah the shit stirrer bitch had her ever so witty post removed and all the rebutalls went with it
in the end- as a r31 owner, I can only dream that my car will be as fast as the ultimate in road cars- a R32 GTST.
Reason is had reports from a member on here ages ago that iwas about 10.5 don't knwo the mile. but if so A associate is planning to run at least a low 10 so looking for something to AIM at :bomb_ie:
Thanks
I think it was 11's by Ryan, that people know of.
Being the car hasnt seen the strip for years it wasnt a bad effort at all.
And from what ive seen, there are a few people aiming for 9's. Albeit thier projects are coming together slower than my one, so it will be a good year before they are back around i reckon :sleep:
bingo....
someone came in and started stirring shit, all the off-topic/abusive/pointless stuff was removed.
Back on topic, here's a vid of GTR_R31's R31 Ti breaking into the 12's :P
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
