Ok i have an r32 gts-t rb20
my mechanic has advised me that my car is starting to have a little bit of engine wear and it might need a rebuild soon
im not sure what to do. if i do decide that it needs to be rebulit or whatever i would like to get heaps more power out of it
if im spending the money might as well go all out.
my problem is i dont know too much about engines ect but im thinking maybe stroke out the little rb20
what would you guys suggest?
im even thinkin drop in a gtr engine or rb25 or rb30 and stroke them out
i really dont know
What do you guys think for price power time ect what are my options?
cheers boyz
$$$ lucky i love my skyline lol
Id go for the RB25 plenty of power easy to modify and very reliable. But if you have the money RB26 all the way, a mate of mine has an RB26 transplanted into a R32 gts4, he performed the conversion himself with great success...
i will probably do one or the other might go rb25
what do you think about working the engine
reckon i should stoke one out?
wanna stick a bigger turbo on too rb20 wont spool up a big turbs
what are the rb30's like?
The Rb25DEt and rb26dett is easy to register in the R32.
Simply ensure the motor is stock running on the stock ecu, quiet exhaust with the GTR/R33 GTST front brakes and its all legal.
IF you go RB30 its not legal and very difficult/expensive to make so. However, the rb30's added torque and its ability to spool large gt35r turbo's the same as an rb20det running its stock turbo is aweseome.
The 3ltr doesn't use more fuel than the 2ltr UNLESS your constantly stuck up it. Mine achieves ~10.6-11l/100km's driving it 'normal' with the odd little squirt.
Drive it hard and 13.5-14l/100km's is easily achieved.
ok see thats the stuff i dont know registering the engine ect
my car at the moment is no where near stock but ive got most of the stock parts
id love to run a big turbo like that tho
i suppose i better talk to my mechanic about all the legal issues
Hey mate here is a sensible option worth thinkin about RB25 with GT30R turbo, Power fc, injectors, pump, etc.. About 250-300kw would be alot of fun in a R32..
yeah i will probably do that id like to be one of the toughest r32 gts-t going around id be happy with that if it dont cost too much
well ive already got most of those parts so if the rb25 is easy to come by and fit well im all for it
rb20 is probably just not enough
Your injectors in the 20 wont fit a 25 so keep that in mind :(
Have you thought about building a high comp RB25DE+T at all???
If your power goal is only around the 220-240rkw mark i wouldn't bother doing an engine swap as you can achieve those results with the 20 and not hurt that back pocket as much.
EG: RB20 with cam gears, injectors, Z32, 2530 (or turbo similar) tuned with either PFC or Remap you would be looking at 230ish reliable and the 20 have a better limiter :laugh:
GMB
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
