As some people know i am working on dropping the RB30det i had in the Black R32 gts-t into a R32 gts4 with 4WD. The motor is just about ready to drop in, Just thought i'd share a few pics of the exhaust manifold i built to low mount my GT3540.
Edited by sky30
https://www.sau.com.au/forums/topic/154768-my-rb30det-into-gts4-build/
  • Replies 49
Posted Images
Very nice... :(
Got any pics of the the exh. manifold with its heatshield on?
Did you manage to get the stock heat shield fitted with a bit of manipulation or are you going to make one up?
If the stock heat shield fits its going to look almost invisible. :laugh:
good stuff carlos.
might be down next weekend
Bring your car cozza, take us for a ride, you had it back on a chasis dyno yet?
Joel:- I had a stock RB25 n/a heat sheild i bent up to make it fit. The RB25 n/a shield has thick white blanket material on the underside which should work good. I see if i got sum pics.
would of by now but thats to an engineering company in qld i now have a bend valve and a couple of chips in my piston, the collet pulled through them billet retainers on weekend. so am going through the legal process of getting it repaired. which could take some time.
Had street machine magizine ask for photo shoot on weekend too. :thumbsup:
26 head this time???, cams??, be a good sleeper this one
cheers
darren
Darren, yeah i went 26head this time for the solid lifters to allow bigger cams and the better GTR plenum.
The aim is to keep it all looking stock, similar to my black R32.
NICE!! - Would like to do this to my GTS4 as well. Maybe later this year.
Like the stealth idea with the heat shields etc.
Can you get to those Cam Cover screws?
My HKS Tubular intake makes it damn hard but possible.
Like the full polished look as well, looks trick.
What sort of price would a manifold like that be worth to buy from you?
Had street machine magizine ask for photo shoot on weekend too. :blink:
Geez... how did you manage that... lol... Long time no see, hope all is well. Wanna see the beast again :P
Geez... how did you manage that... lol... Long time no see, hope all is well. Wanna see the beast again :blink:
If it helps, blew a tyre last night doing the speed limit funny enough on the new front left tyre. Ended up with alot of hours lost, damaged radiator hoses, thermo fan had to be repositioned and wiring re-done, and exhaust re-heated and put back into shape (that was from the trailor).
Miss ya on the cruises mate, hope to catchya soon, and if you manage the photoshoot this weekend enjoy :P
Ash:- yeah, getting close, still got cams here (sitting in cupboard), just havent been to adelaide for about 6 months.
Joel:- head is only temporary bolted on ( havent done final assembly), i have blocked off the rear oil feed with a screw i made, i may be interested in that restrictor. what do you think i should run 1.8 or 1.5mm oil feed at front and rear blocked??
Joel:- I thought the 1- 1.2mm were for those running GTR or N1 oil pump, im only using a std RB20det pump, thats why i thought id stick with 1.8mm, or 1.5mm.
Are RB20det pumps same or nat as much flow as RB25det pumps?
Do RB30 blocks come std with 1.8mm restrictors??
    • That would be interested if it's the case as seems like it would make the job a lot messier but subaru sells OEM gaskets so seems it might of had it.
    • Fuel tank is out. Looks pretty bloody good under (ie above) the fuel tank.  Amazing how good the factory e-coat holds up in the hidden areas.  No where near as much body deadener to get rid of as the front but still not looking forward to it!  Shit of a job.  I'm thinking I might grab a needle scaler and give that a go before I attack it with the angle grinder and wire wheel which is how I did the front 2/3's of the car.  Feels good to be working on the car again but who knows how long it will last!  Hopefully I can get it further forward than where it was prior to this last block of work when I decided to go back 10 steps further down the rabbit hole from where i already was! The problem is, I'm realising how hard it will be to repair and paint the bumpers, which cannot be put back on the car, and have a good paint match. There are also areas where it would be VERY hard to hide the new paint where it transitions from old paint. Like this- There is only one way to do that perfectly and I really dont want to have to do what that means I would have to do... 🤦‍♂️
    • Pretty sure the factory assembly doesn't have any gasket at all, just RTV.
    • I will get a couple cans for sure thanks, I do have 2lt fish oil to spray around the car already.
    • Thought I’d post pics of the packages for those interested. The premium package is #16. Remote start, security with tilt sensor and remote and backup battery, auto fold mirrors and door illumination.    Can post up pics of all the factory options and images from the factory options brochure if people are interested. I have all the dealer books etc for all rv37 models.
