Bough a second hand gearbox today and guy said it was fine. Anyway, cleaned the outside a bit and emptied transfer case fluid and gearbox oil out.
On the gearbox magnetic drain plug there was a couple of metal clips about 4mm long with the smaller bits that had broken off the clips.
Would anyone know what part they would of come from? I'm guessing part of the synchros?
I'm going to pull apart box and check it out when I have some spare time.
Here's roughly what they look like, don't have camera atm!
Pretty sure they go on the selector forks. you may have a snapped selector floating around in there or at least these little bits have fallen off. not sure what harm if any would be done by running without them, but if you have the will and the time I'd say opening the box wouldn't be a bad idea.
yeah they are. but what i dont get is how do they "fall" out
I have never come across this before!! I'm gonna check out the manual to see exactly where they go.
There were only two clips that were on the mag plug and the little tabs that can off with em.
Guess they didn't like their home!!
You have a few broken "paws" and retainers there.
Interesting part is how the hell did they got out of the hub without the hub phsically breaking apart of the baulk ring shattering.
Beats the hell out of me. Had a look at parts breakdown and they are inside the hub like you said.....
I'm just not looking forward to pulling apart another gbox. Pulled transfer case off my first blown gbox(blew 3rd) and haven't touched it since(lazy).
I bought gbox thinking it's ok after running through the gears and turning shaft. The guy said it's okay, but they all get a flogging.
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
    • 12.8 for a great condition, fully charged battery. If the battery will only ever properly charge to about 12.2V, the battery is well worn, and will be dead soon. When I say properly charge, I mean disconnect it from the car, charge it to its max, and then put your multimeter on it, and see what it reads about an hour later. Dieing batteries will hold a higher "surface charge", but the minutest load, even from just a multimeter (which in the scheme of things is considered totally irrelevant, especially at this level) will be enough over an hour to make the surface charge disappear.   I spend wayyy too much time analysing battery voltages for customers when they whinge that our equipment (telematics device) is causing their battery to drain all the time. Nearly every case I can call it within about 2 months of when the battery will be completely dead. Our bigger customers don't even debate it with me any more ha ha ha. A battery at 12.4 to 12.6 I'd still be happy enough with. However, there's a lot of things that can cause a parasitic draw in a car, first of which is alarms and immobilisers. To start checking, put your multimeter into amps, (and then connect it properly) and measure your power draw with everything off. Typical car battery is about 40aH. Realistically, you'll get about half this before the car won't start. So a 100mA power drain will see you pretty much near unstartable in 8 days.
    • Car should sit at 12.2 or more, maybe 12.6 or 12.7 when fully charged and happy. If there is a decent enough parasitic load then it will certainly go lower than 12.2 with time. You can't beat physics.
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue. Isn't 12v low, shouldn't it be around 12.5v?
