hmmm. i bet it was making a nice wir wir wir wir noise yes?
the corect tension is no slack. oh eay way to check is by flapping it like you do a rubberband. if it makes a audible twang. its to tight.
if it makes a thud its just right :thumbsup:
  • Replies 57
yes it whirred nicely
and it didnt twang when flicked when we did it
if it makes a thud its just right :huh:
ahh subjective. :thumbsup:
I setup mine with the correct tension as per the engine manual. It had slight slack but was not loose. It had tension if that makes sense. :laugh:
My initial feeling was... It should be slightly tighter. But its not supposed to be 'tight'.
Like me,try to move forward.If finances are ok then rip the head off and check damage.If pistons are ok then perhaps a port clean and even cams.Otherwise locate a standard head and bolt her back together.Do you feel you could rebuild it yourself if pistons are gone?
considering im unemployed im not ripping it apart unless i gotta, comp test it is as B|4cK32 said
gates high performance ones HRthirtyone?
Edited by Rednisr31
yea dude, the blue ones, that are meant to be 3x stronger etc.
if you dont have cash to fix it straight away, park it up , and take the head off..... Dont even bother with a compression test, you should have bent valves. it wont hurt to take it apart and suss the damage.
should, ya never know tho i might just be lucky
my mate was smashing limiter with his rb30e and snapped a timing belt and it didn't damage it internally
I think rb30e are considered not interference engines, meaning the valves can neve rhit the pistons.
In a rb25 howver i believe ther are a interference engine so yes the valves will smash the tops of pistons.
Hope fully im wrong.
Sorry to see that happen.
the following was taken from the service manual for r33 gts25t.
"6. Adjust timing belt tension.
(1) Turn the crankshaft clockwise twice with the tensioner pulley
installation bolt in loose position.
(2) Insert wrench to tensioner pulley hexagonal hole to fix the tensioner
pulley to tighten the installation bolts.
Tightening torque (N-m{kg-m}) 43-58 {4.4-5.9}
*The timing belt tension should be at correct tension"
Ouch thats nasty and making me freak out a little bit.
I had a Gates belt fitted a couple thousand kms ago and it whirrs very loudly. The belt cover is off and I dont think I could get 10mm play in it.
The mech that fitted it said it will loosen up after a thousand or so kays and that the whirring noise is perfectly normal. Will I have to do the whole belt replacement procedure i.e timing etc to loosen it or can I safely just loosen it off a little bit with it all in place?
I have never done it myself before hence I dont know how the tensioner operates.
to adjust the tensioner u need the bottom timing cover off which means u need the fan off and radiator out and harmonic balancer off as well, so pretty much the whole lot (and top timing cover but u say its already off). its not hard to do a timing belt and i cant see how people make it out to be a difficult job. i can get the car from running to belt off and new one on and runnning again in about an hour and a half or less. ive done mine about 20 times though when we been doin the valve shim clearances for the big cams i got.
oh and no the belt doesnt actually need to be removed only the tensioner loosened abit with belt in place.
just make sure the 3 dots line up and u will have no problems for anyone attempting the belt change themselves :laugh:
Edited by CruiseLiner
rb30s are interference engines
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
    • You 100% could do that, would save money on a gym membership lol. But yeah, getting a cordless orbital sander will feel priceless coming from doing it manually.  Good luck with it mate
