  • Replies 60
Yeah, I have a feeling the bleed valve is dodgy since it was a home chop job by the previous owner. Its been taken in and out before because the car had to pass the pits.
Spoke to a guy at a workshop that I've booked in next week, he says its probably a dodgy piece of vacuum hose and they can replumb it for me, or just take the whole thing out and put it back to factory boost (which isn't a bad idea considering stock internals) so that way I'll at least be able drive past 5000rpm safely. Pretty simple job, but I guess I'll leave it to a pro to fix as I've been quoted about $60 for an hour's work on it plus the cost of a new bit of vacuum hose (although I reckon your average mechanic will probably fix it in 10 minutes).
Will let y'all know how it goes when the car goes into the shop. Thanks for all the help people :)
All done. Just took out the bleed valve and replaced the vacuum hosing for about $20.
The down side is now the car doesnt feel half as fast as it did before I took the valve out and the boost was going through the roof :rolleyes: but I suppose at least my turbo isn't going to blow...
The car is boosting happily away at 0.4 bar now all the way to 7000rpm(?) limiter - which brings me to my next question: my redline is at 8000rpm so why is my limiter kicking in at 7000? it just bounces on 7000 and doesnt want to go any higher. The boost cut is gone however.
is it possible that the redline was lowered with the powerfc previously installed? is this hard to reprogram if so?
If not, does this problem sound like anything else?
Sounds like your boost has been returned to the stock output [by way of the vacuum hose replacing it - as you said]. So boost should be approx .55 bar [which = 7.9 psi]. Of course your boost limiter wont be there anymore...it isnt reaching high enough to hit this limiter [which is supposedly 1 bar]. You can probably ignore the factory boost gauge because it isnt accurate and its not in bar or psi anyway [kg/cm2]. Where did you get your figure from [0.4bar]? An aftermarket gauge or what?
Rev limit from factory is somwehre between 7000 - 7200. I know this because I have a stock ECU in my 34 and have recorded on a dyno up to 7100rpm and YES mine cuts out occasionally when I hit this range too.
If your display / rev gauge is not the original nissan one [such as tommy Kaira / Nismo etc] then the actual REDline marking could be anywhere [such as 8000] but the factory rev limiter may still be in operation [at the default value of around 7000].
I am sure the PowerFC would be able to control the rev limit but this is the risk you take when buying a modified 2nd hand car - risk as in, you dont know what your getting or what settings there are. You are asking some questions that are unique to your car and can't be answered by any of us! I hope I have been of some help though!
If you want more power get someone to put a bleed valve in properly or get an EBC [electronic boost controller]...If you are used to your car's power with more boost than stock, of course it is going to be slower now...
Zahos: nah, the guy took it out. I figure if I want to increase my boost I might do it later with an EBC of some sort, or at least some sort of in-car adjustable valve.
NismoR34: I got the reading from an Apexi a-pillar boost gauge. It sits on 0.4 all the way to 7000rpm. My dash is the stock Nissan dash and I'm quite sure the redline on the tacho starts at 8000rpm - so does this mean that the redline on the dash isn't really the redline set in the ECU? Does your dash have redline markings from 8000rpm?
All this could be purely academic if the engine shouldn't really be revving past 7000 anyway, regardless of where the markings on the dash are - I realise that. But I'm just curious why it cuts out at 7000 when the redline on the dash is at 8000.
And one last thing, 0.7 bar the figure I'm getting to be the safe boost level for stock internals/turbo on an R34 for street use - can you guys confirm this?
And yes Nismo/Zahos you guys have been a big help and its much appreciated :P
No worries....
Yeah, 0.7 should be quite safe. You could probably run a little higher for street use (squirst here and there), but 0.7 should be just fine.
Zahos
No my markings start at 7000 which is a broken red line [- - - -] and then the unbroken red line [----] starts at either 7500 or 8000 approx and goes all the way to the end of the tacho @ 9000rpm!
*brainstorm* With the vaccum hose that now sits in place of your previous boost valve, did they put any restrictors in there? I am guessing they havent! The standard hose has 2 metal restrictors inserted at either end of this hose, when I removed these 2 restrictors the boost dropped! This sounds like what you now have. Which is less boost than standard. I dont know where you could get restrictors from so I would suggest getting a boost controller in ASAP!
Yep. Just spoke to my mechanic, he says boost is pretty low at the moment (0.4 bar or around 6 pound) and that he regularly sets up customer cars up to 1 bar boost on stock turbo/internals safely (although he'll have to dyno it to test and make sure nothings going to blow up). I plan to get some EBC or dual stage boost controller. Mechanic said the cheapest way is to go the bleed valve/boost cut defender option and stick it up to 1 bar or thereabouts.
For the moment, the boost is going to have to wait - my alignment is out, and the wheel alignments were out by varying degrees on the left and right sides of my car - suggesting an accident and the need to use a chassis alignment rig (*sighs at buying cheap accident repaired japanese import*) to stop the car pulling to the left on a flat road :P
Oh as for the redline, my mechanic said that theres not much point going over 7000 anyway because the car drops right off its power/torque band at around 6600, so I really should be changing gears about then anyhoo.
I'll have to go home and double check my dashboard redline.
Your redline will be the same as mine - unless u have got an undercover GTR :(
I just remembered an ultra-cheap way to increase boost a little - use a cable tie to crimp [restrict] the hose a little bit. The other cheap way is to do what I did, fit a bleed valve. I fitted mine myself and it cost me like $25 total. Check for sale section or post a thread in WTB there may be some for sale around this place.
If I were you I would only increase the boost up to around 10psi or 12 psi at the most [1 bar is 14.5 psi]. HPI's r34 GTT project car had their turbo blow up at just .85 bar whilst flogging it around the track. You may not take yours on the track but do you wanna risk it for the sake of a bit more power now?
Most sensible people in the "turbo car" industry agree that 2-3 psi above standard is okay for stock turbo's / engines. Standard being approx 8psi. Its up to you though!
Hey mine pulls a bit to the right, but not too badly.
Dyno testing can be very helpful in finding out your cars power, boost setting, air/fuel ratios, state of tune, problems - like detonation etc...I had mine dyno'd and power was peaking at 7100rpm's when the rev limit kicked in so changing gears earlier on mine is not optimal especially in drag racing...Nissan quote 6400rpm as peak power on a standard car, which most of ours are not...
:confused: now you have made me wanna go and check mine...though I am already 99% sure it starts at 7k...
icon3.gif...another brainstorm, instead of going out to the garage which is all of 10 metres away I will sift through a hundred odd photo's on my pc cause I am sure I have got a pic of my dash here somewhere...*goes and browses*
...hours later [:)]...
icon3.gifah ha, in fact I posted a pic on SAU before...now I just got to find that link...
aahh there it is
See 7000rpm redline! If your dash doesnt look like that then it isnt the stock nissan one [for a 34GTT].
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
