Hi, i've been having major hesitstion and holding back problems with my R33 GTS-t i hav ereplaced jus about everything to try and cure it and ihave gone through all the main things that go wrong with them to cause them to either hold back or missfire!
i checked the timeing the otherday and it was out by about 5-10 deg so i tried to adjust it on the cas to move the timeing along and i got it bang on 15deg! the car ran like newand was great i parked it up didnt touch it till the next morning and it was crap again i checked the timing and it was out again!!!!!
i took the cas off and noticed that the rubber o ring around the end of it was broken and was in half so obviously it well off now when i try to adjust the timing it gets to about 10 deg and i move it a little more and it jumps to about 35!!!!! then i have 2 knock it bac and it jumps from about 25 to about -10!!! i cant get it inbetween!!!!!
any ideas on what coudl be causeing this error???
thanks alot! :laugh:
Be very careful guys.I had similar problem with timing all over the place and performance would change from one minute to the next.Turned out it was the timing belt missing half it`s teeth because the dumb shit mechanic used a mitsubishi belt.
I had mine chaged 10tho kays ago wiht a gates racing one.
ROX best take it to a mechnic could be a numbe rof things from, Fuel pressure, airflow meter, timming.
I go tmy car booke din for a PFC tune and to sort out the CAS issue on the 17th so i will let u know after what the solution was for me. Apparently the cas can go bung and sometimes read 0 or 15 and all over the place. On my PFC the read out ofr timming is fine doesnt seem to move? but i dont know if the PFC actually shows wha tis really going on with timing? does any one know?
i have had this happen on a mates engine before, the CAS had a broken shaft onto the cam, seemed to pull out fine most of the time when i thought it was suspect and checking it, then one day pulled it out and only half came out. split where the roll ping thing joins it. i assume that at revs (got to the point it was doing it at idle) that the timing was jumping around everywhere ... simply replaced it and wammo
    • I'm not sure the diode only will give the desired result. I'd probably approach it with a couple of relays (And you still might need a diode too!). You need to be able to break the constant feed from the headlight to the orange corner globe when the indicator is flashing. Not knowing which Skyline we're talking about specifically here too (And it may not matter, but I don't know the R34 column switches) you'd likely need to rewire the stalk, so that the indicator power itself no longer runs through the stalk too, as now you need it able to trigger a relay that will break the constant supply from the headlights to the indicator, then you'll need a separate relay to trigger the indicators to come on (Replacing the internal action of the indicator stalk).
    • Weird story from me My Toyota 86 was with Commbank comprehensive but for market value (who they use to underwrite is unknown) When I munted it beyond financially viable repair in 2020, rear end smashed in to the point it bent the rear quarter and roof, they knew I paid $31k cash for it because I told them, they still paid me out $38k, as all the 2017 limited edition variants with typical Km and condition were going for between $36-41k, so they did weird math and came up with $38k I never officially mentioned any of the mods that I had done, but as they were not the cause of the crash they were not fussed at all, the insurance inspector actually asked if I wanted to replace all the mods with the OEM stuff if I still had it laying around before they took the car I still came out of it behind though, because I had probably dropped $20k in it with the suspension (bent after the prang), wheels (bent as well) and "other" mods, that the inspector asked about But still, as the market value was higher than what I initially paid, and they paid out market value To say I was surprised with the outcome would be an understatement  Weird, but true, but probably just lucky with the inspector on the day I guess  Sadly, I don't think if I munted the old NC1 MX5 I would get the same result Meh, pay to play
    • Well, the car is back, all straight and shiny, for how long for is anyone's guess  After picking it up we went for a bit of a drive, Jebus I really enjoy driving this little thing, hopefully the weather let's us go for a nice long cruise this weekend as it will be out of my hands for at least a few days next week when it heads back into Mania on Monday It's weird, whilst I do always enjoy going for a drive, the NC makes me feel like a kid who has just got his first car, and they just want to drive wherever and whenever they can I really need to look into the MX5 Club of NSW
    • wow that is some seriously JDM original credibility there!
    • Selling hks rb25 cast manifold and waste gate.   Never going to use as don't have Rb powered car  Unknown condition of waste gate diaphragm  $900 Pick up only Ipswich Qld
