2006 Intense Sabot XL blue 20" BMX
It has sealed cartridge bearing hubs, headset and bottom bracket. The rims are Sun Rhyno Lite double wall, eyeleted rims. The hubs are Redline Flight series hubs. The cranks are Redline Flight series with a Profile Inferno 41T chainring. The forks are Dynamic BMX carbon/alloy forks. The stem is an Odyssey Elementary stem (super light stem), the seat and post are Redline Flight. It has a THE padset. The gearing is 41/15. Selling as I am no longer racing.
pics up shortly.
$800
2003 Giant TCR road bike
The frame is a 6061 alloy frame with smooth welds. The frame has some small scratches. It has carbon fibre forks and seat post. It is running a full Shimano 105 9 speed groupset, with Shimano R540 wheels and red/black Michelin Pro Race tyres. It also has a Ritchey stem. The bike has done approx. 350kms. Selling due to being too lazy to wake up early to go for a ride, and i need the money.
$1000
Pics will be up shortly.
Edited by mad082
https://www.sau.com.au/forums/topic/154870-bmx-and-a-road-bike-for-sale/
    • Is rebuilding it even a thing? Where would the shop find parts for it? I looked at some off these local online stores for my r34 and suprisingly they had brand new aftetmarket ones for $600-800 I think. I guess r32 might be a bit tougher.
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
