Make/Model: R31 Skyline TI
Year: 1989
Kilometers: 285,000
Transmission type: Manual
Engine: RB30E
Colour: White
Modifications: Import Struts, Koni Reds all round (~ 6 months old) with lovels sports low springs, R33 twin piston front brakes with EBC greenstuff pads, Recondonditioned rear calipers with bendix metal kings, Near new RDA slotted rotors front + rear, Cusco Camber Tops, Wildcat extractors, 2.5" exhaust, 3.7 Silo LSD, Manual Conversion with R32 RB20DET gearbox and Exedy clutch, 16" 'Performance' rims with Falken tyres less than 6 months old fit with no spacers, GTS1 Front swayber + whiteline rear swaybar, Noltec adjustable panhard rod, oh and POD filter :laugh:
Roadworthy Certificate: Will be provided after deposit is received
Accident History: Rear ended another car 2005
Asking Price: $3500 neg $3000 for you guys
Contact Details: Call Martin 0421 809 268 or reply or PM
Other Comments:
Pioneer door speakers and pov spec CD player included. Full auto electric arial.
Will through in a DVD player, In Dash DVD, Sub and Amp Uninstalled for an extra $500 (Pending testing that they actually work)
Damage from accident has been repaired but bonnet has a dent and both bonnet and filler panel really need paint.
LSD works pretty well in the wet, not so good in the dry but better than single spinner.
Cracked a head a year or so ago so she got a brand new head, radiator, thermostat, water pump etc then. Also got new belts including timing belt.
All electrics work (except cruise which has been removed), air con is icy cold, in fact it actually spits out bits of ice sometimes on high :P
Has immobilser with keyless entry,
All bushes have been replaced with nolathane a couple of months ago, as well as new ball joints.
Power steering has a slight leak (needs about 1 cap of fluid every 6 months)
Spent well over the asking price in the mods not to mention the cost of the car when i bought it but i want quick cash so priced to sell!
Great car to buy with suspension and brakes already done ready for a turbo upgrade or maybe a 30DE. Turns well and stops on a dime.
Pics from a little while ago, nothing much changed since then:
Close up of rims and R33 brakes:
Interior Pics:
http://members.iinet.net.au/~ian.m.smith/tiint/
car hands free kit and GPS receiver not included.
https://www.sau.com.au/forums/topic/154881-sold/
Why was the cruise control removed ?
The whole system, or just the drivers control from the drivers compartment ?
Also, I assume these pics are PRIOR to the accident damage occurring ? as I can't see any damage in the pics whatsoever.
Fine looking car as it was then.
Edited by Simon_Koala
https://www.sau.com.au/forums/topic/154881-sold/#findComment-2880219
Cruise control was removed coz it was broken (worked maybe 60% of the time). And when I did the manual conversion I could'nt be bothered wiring in the clutch cut out switch since it didnt work properly anyway. So i just ripped it out. The loom is still in there, and the throttle body has the extra cable fitting, but there is no servo or interior controls in the car.
The pics are after the accident, if you look carefully at the bonnet you can see the paint looks less glossy. Its more obviousy in the flesh, the photo tends to hide it a bit. You can't really see the dent in the photo either.
https://www.sau.com.au/forums/topic/154881-sold/#findComment-2881920
Guest
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
    • Hi all, I thought I'd put one of these references in here before but it seems I haven't - not sure how many people are actually using this place still but I feel like there are guys lurking about who might find this reference useful or interesting.  A lot of the time people don't catch key details or even fully understand how compressor maps work - or don't even look at them and just go from heresay about deciding how different turbos may compare, but I've been putting together this table over the years as a quick reference to get a gauge of how certain compressors compare to cut down the time that can be wasted looking around aimlessly. * This relates purely to compressor flow, so won't necessarily reflect the outright capabilities of these turbos as the power potential also comes down to the turbine side.  If you understand this, you should be able to use this 😃 * The inducer and exducer size listed are the mm of just the compressor wheel * The values under the "psi" headings are "lb/min airflow" and reflect the maximum airflow that compressor supports before it's efficiency dips under 65%, or it reaches it's maximum speed - whichever comes first. Any questions, or requests for other turbos which the compressor map is available for then let me know 🙂
    • And what you pay for a pack of 8 bolts and nuts at Bunnings, will land me 200 of the same nuts and bolts from a fastener shop.   M12 * 1.25 IS a standard. It's not like ordering M12x1.25 and hoping the thread pitch is right. Unlike ordering an ounce, will get you 4 different amounts depending on which ounce someone takes it to be. Your issue is a supply issue.
