hey guys i looked see if this has been covered before but i couldnt find anything how do i keep the aerial down? it is huge and unslightly i dont like it when it is up makes my car look like a R/C car!
thanks
LOL my r33 was fitted with a swith so i can flick it and the ariel does not extend.
I guess its a simple break the right circuit and add a switch job. Any auto elec should be able to do something fairly cheap.
https://www.sau.com.au/forums/topic/154890-aerial/#findComment-2880450
thanks
Your best option is to take out your head unit and get the trigger wire that gives power to the aerial and chop it, put a switch with a relay between the trigger wire from the head unit to the aerial wire and hide your switch somewhere, that way if you need the aerial just flick the switch and if you dont then leave it completely down... now you've given me an idea i'm going to give it a try lol
https://www.sau.com.au/forums/topic/154890-aerial/#findComment-2880455
haha i have given you an idea, yer it is just that the aerial is sooo huge it is tall as me wen it is out and just looks comical. I have never taken the head unit out the audio shop did that for me so i dont have a clue about getting inbehind the unit. Any pointers or instructions on getting inbehind there? iam also not full wack on the electrical side of things and would hate for something to go wrong while iam making switch and what have you. So could i simply just disconnect the aerial, i mean who listens to the radio :laugh:
https://www.sau.com.au/forums/topic/154890-aerial/#findComment-2880507
LoL, your best bet would be to get in behind where the actual aerial is in the boot cos it could get a bit messy if your unsure. Just take off the panels in the boot wich would be more easier to access than the head unit, and unplug the aerial :laugh: but only unplug the plug going into the aerial not the antenna cable cos it'll still go up lol.
https://www.sau.com.au/forums/topic/154890-aerial/#findComment-2880656
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
    • Brumbys with good shells are bloody expensive, I've looked at 2 "cheaper" cars, and walked away from both,  plus after some research spare parts are fairly sparce I'm starting to think that I missed the boat on finding a clean one that is straight (ish) and without alot rust I'm starting to think about a old Hilux as panels and other parts are much more available as they sold tens of thousands of them I use to be indecisive but now I'm not sure
    • A Brumby would probably fit a big metal toolbox in the back... this is how it begins
    • Picked up a new OEM boot seal for the MX5 today as the old one got ripped a bit by me being a idiot by seeing if I could fit a large metal tool box in it, it didn't fit, and ripped the seal with the corner of the tool box I am still waiting on time to get the cams and new balancer installed, as well as the repairs to the boot Time will not be an issue soon though
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
