boss wants Huddy and I to five stud works skid ceffy
using 5 stud gear off a stagea front and rear cross member we have a work
just read that you can't use r33 stuff to five stud a s13
seeing as there around the same era thought I'd ask here before we get stuck into it
stagea setup we have seems to have the same brake setup as the ceffy has atm
I'd much prefer just to stick the motor in (T04r mmmmmmmmmmmmm) but he wants five stud
so Ive gotta be a good little worker lol
Edited by 1400r
https://www.sau.com.au/forums/topic/154891-rwd-stagea-5-stud-on-to-ceffy/
  • Replies 73
Posted Images
im keen to help
done it 3 times over on 2 cefs
whats he got lined up for the front?
i would recommend using (as we have discussed 1000 times in the past) r32/z32 rear hubs... slides straight into the stub axles on the cef and retains the drum setup (wally has em for 50 bucks each... or im sure being kansai automotive you surely have a pair (i have 1 z32 and 1 r32 one so theyre identical))
and then use r32/r33 rotors and whatever calipers you want aslong (32 type m/r33 gtst... same shit twin pot rears which will bolt to factory mounting points on cef stub axles)
all youll need to do is cut or remove the brake dust cover
for the fronts... thats another story
i have thurs/friday/saturday/sunday off so...
gtr is fine... too much shit with this whole 5 stud conversion thing is interchangeable
its nissan
to be honest i havent played with stagea... if it runs same balljoints as s14 you can use it by getting r33 balljoints pressed into the lower control arms and stub axles (now dont go asking why cant i use r33 then if i need r33 balljoints... think about double wishbone strut mounting points compared to normal suspension in silvia/cefiro)
you can use r32 front hubs also into the factory cefiro stub axles im 99.9% sure which makes it easy like the rear
go find 4 r32 hubs... slot em into your stub axles and get some 5 stud rotors n brakes (im assuming terry will go r33 gtst all round) and whack it on... bobs your uncle easy 5 stud
btw ryan i finally have driven my car with the 5 stud i got off you guys... front wheel bearings are shot... hope terry can give me a hand!
"btw ryan i finally have driven my car with the 5 stud i got off you guys... front wheel bearings are shot... hope terry can give me a hand!"
your joking right
you mean you didnt put new wheel bearings in when you swapped them over...?
cheap fix would be to put your old ceffy wheel bearings in assuming they'd fit
that help
dont think theyd fit s14 hubs?
nissan want 310 a bearing
cbc bearings want 305.60 a bearing!
ive got wed/thurs/fri off so ill come past n show you my BEARINGS and the vibrations which they are emitting throughout my car which is kinda turning me on...
and once again the 5 stud discussion lol
Well sounds like most of you guys are mechanics or have access to workshops with a press so you can mess with the S14/R33 ball joints.
But for the non technically minded (me) and the people that dont have access to a workshop (me) Try these little puppies for $550 from Just Jap, including front wheel bearings.
http://www.justjap.com/forumhubspecial.htm
All the information you could want is here
http://www.nissansilvia.com/forums/S13-and...50-t107311.html
Just dont do what I did and buy R34 Calipers as they use bigger bolts. (I made them fit though :thumbsup: ) More info on that here. (only if your bored)
http://www.skylinesaustralia.com/forums/in...howtopic=139091
well im not sponsored so i dont automatically get that - must haggle >_<
sall good... markys wisdom confirms wheelbearings - he told me all the symptoms without driving the car and me telling him what is wrong... so yes its bearings
and a mate owes me alot of money - he cant pay up... so i collected some parts - including s14 front hubs with good condition wheelbearings :)
so that fixes that this weekend
see you dont realise that things are priced at that price for a reason - its not a garage sale... its a business - i suppose thats why you want 400 for those over fenders when you could more than likely source some for $200 set brand new...
so... if thats that sorted - you doin skids on saturday in your drift car?
i do realise this - but you cant haggle with businesses? some of us know what stuff actually is worth... thus we haggle
not saying kansai is expensive at all - just e-war with huddy
no my fully sick drift car is receiving maintainence over this week... need to adjust preload and height on coilovers, install kazama castor rods, exhaust is getting fixed on saturday, need to change front hubs due to screwed wheelbearings and fix some random kreeks and clunks
oh and if i can be f**ked swap my rear calipers over so theyre on the right sides :laugh:
Edited by Hella Flush
300+ a bearing? I find that very hard to believe? you sure they are quoting for a complete hub? I think I got 4 bearings for my silvia for about 60 bucks each? Had to press them into the hubs myself though.
yeah i actually went into nissan
and theyre like oh whoops we meant full hub assembly with wheelstuds etc... and they wont seperate the bearing from the kit
all good though mate owes me money so as part of the money oweing im getting his good condish s14 hubs
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
