boss wants Huddy and I to five stud works skid ceffy
using 5 stud gear off a stagea front and rear cross member we have a work
just read that you can't use r33 stuff to five stud a s13
seeing as there around the same era thought I'd ask here before we get stuck into it
stagea setup we have seems to have the same brake setup as the ceffy has atm
I'd much prefer just to stick the motor in (T04r mmmmmmmmmmmmm) but he wants five stud
so Ive gotta be a good little worker lol
Edited by 1400r
https://www.sau.com.au/forums/topic/154891-rwd-stagea-5-stud-on-to-ceffy/
  • Replies 73
Posted Images
im keen to help
done it 3 times over on 2 cefs
whats he got lined up for the front?
i would recommend using (as we have discussed 1000 times in the past) r32/z32 rear hubs... slides straight into the stub axles on the cef and retains the drum setup (wally has em for 50 bucks each... or im sure being kansai automotive you surely have a pair (i have 1 z32 and 1 r32 one so theyre identical))
and then use r32/r33 rotors and whatever calipers you want aslong (32 type m/r33 gtst... same shit twin pot rears which will bolt to factory mounting points on cef stub axles)
all youll need to do is cut or remove the brake dust cover
for the fronts... thats another story
i have thurs/friday/saturday/sunday off so...
gtr is fine... too much shit with this whole 5 stud conversion thing is interchangeable
its nissan
to be honest i havent played with stagea... if it runs same balljoints as s14 you can use it by getting r33 balljoints pressed into the lower control arms and stub axles (now dont go asking why cant i use r33 then if i need r33 balljoints... think about double wishbone strut mounting points compared to normal suspension in silvia/cefiro)
you can use r32 front hubs also into the factory cefiro stub axles im 99.9% sure which makes it easy like the rear
go find 4 r32 hubs... slot em into your stub axles and get some 5 stud rotors n brakes (im assuming terry will go r33 gtst all round) and whack it on... bobs your uncle easy 5 stud
btw ryan i finally have driven my car with the 5 stud i got off you guys... front wheel bearings are shot... hope terry can give me a hand!
"btw ryan i finally have driven my car with the 5 stud i got off you guys... front wheel bearings are shot... hope terry can give me a hand!"
your joking right
you mean you didnt put new wheel bearings in when you swapped them over...?
cheap fix would be to put your old ceffy wheel bearings in assuming they'd fit
that help
dont think theyd fit s14 hubs?
nissan want 310 a bearing
cbc bearings want 305.60 a bearing!
ive got wed/thurs/fri off so ill come past n show you my BEARINGS and the vibrations which they are emitting throughout my car which is kinda turning me on...
and once again the 5 stud discussion lol
Well sounds like most of you guys are mechanics or have access to workshops with a press so you can mess with the S14/R33 ball joints.
But for the non technically minded (me) and the people that dont have access to a workshop (me) Try these little puppies for $550 from Just Jap, including front wheel bearings.
http://www.justjap.com/forumhubspecial.htm
All the information you could want is here
http://www.nissansilvia.com/forums/S13-and...50-t107311.html
Just dont do what I did and buy R34 Calipers as they use bigger bolts. (I made them fit though :thumbsup: ) More info on that here. (only if your bored)
http://www.skylinesaustralia.com/forums/in...howtopic=139091
well im not sponsored so i dont automatically get that - must haggle >_<
sall good... markys wisdom confirms wheelbearings - he told me all the symptoms without driving the car and me telling him what is wrong... so yes its bearings
and a mate owes me alot of money - he cant pay up... so i collected some parts - including s14 front hubs with good condition wheelbearings :)
so that fixes that this weekend
see you dont realise that things are priced at that price for a reason - its not a garage sale... its a business - i suppose thats why you want 400 for those over fenders when you could more than likely source some for $200 set brand new...
so... if thats that sorted - you doin skids on saturday in your drift car?
i do realise this - but you cant haggle with businesses? some of us know what stuff actually is worth... thus we haggle
not saying kansai is expensive at all - just e-war with huddy
no my fully sick drift car is receiving maintainence over this week... need to adjust preload and height on coilovers, install kazama castor rods, exhaust is getting fixed on saturday, need to change front hubs due to screwed wheelbearings and fix some random kreeks and clunks
oh and if i can be f**ked swap my rear calipers over so theyre on the right sides :laugh:
Edited by Hella Flush
300+ a bearing? I find that very hard to believe? you sure they are quoting for a complete hub? I think I got 4 bearings for my silvia for about 60 bucks each? Had to press them into the hubs myself though.
yeah i actually went into nissan
and theyre like oh whoops we meant full hub assembly with wheelstuds etc... and they wont seperate the bearing from the kit
all good though mate owes me money so as part of the money oweing im getting his good condish s14 hubs
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
    • So my car is finally back from paint! This took an absolutely insane amount of work and should get it's own build thread - but I didn't build it. It was completed by Troy @ https://scalekustoms.com.au/ I originally bought the AOSHIMA URAS Type R kit while I was in Japan, it's supposed to look like this when assembled: Now, I thought that was cool enough until I opened the box with Dismay, as there's no way I could possibly have completed it. The thing is 1/24 and has details down to the steering wheel horn button, which is a 2mm diameter sticker. I originally wondered if someone could make it at all, as is - But then things got a little carried away. It's worth noting that the model does not have an openable bonne, let alone engine bay, OR an openable boot. - Troy has worked wonders with 3D printer and presumably better eyes than I will ever have. My photos suck, so I will post up some of his in-progress ones he sent to me during the way. Unsuprisingly, he is very detailed. A lot of these are out of order. But he: 1) Made a LS engine and an engine bay appear out of thin air 2) Made the bonnet removable 3) Printed the rims I will buy in the future (or any rim you want) 4) Printed and added the wing that is going on 5) Tinted my back windows as this is what my car has IRL (privacy glass) 6) Added a licence plate. 7) Somehow did the interior 8) 3D Printed my actual seats 9) Made the exhaust under the car connect even though this is likely invisible. 10) Created a boot with my fking battery box, power steering reservoir, subwoofer and toolboxes back there. To say it's insane is an understatement. And I f**ked it all up because when I was re-mounting the wing (it broke in transit) I spilled glue everywhere and ripped paint up and Gregged the rear half of the car. Which about makes sense. Also, this arrived on the same day. Quite the change from: I spent 16 hours per day over the next 3 days pre-christmas putting the interior back together, mounting lip, fixing various bodykit problems with window mouldings, etc. and servicing, rebuilding my 370z brakes to go on the car 'soon', messing with heights to check clearances for new wheels, etc. I also had a foray into mounting wiper-mounted washer jets which was an absolute disaster. The bodyshop has welded (and painted) over the stock jet locations for reasons unknown to everybody (i.e they forgot) I also wanted to wire in the oil pressure sensor on Christmas Eve which was a BAD IDEA. You do not know terror like pulling your ECU apart, pinning in half-fitting pins that aren't the right ones, but trying anyway because it's Christmas eve, putting your ECU back together and having a no-start condition with a fuel pump not priming. Then you undo all your work and the fuel pump still doesn't prime. So after all that terror and horror and pain and tedious disassembly, the issue was the relay in the boot which seems to have died/stuck when I was turning the car off and on about 700 times testing shitty washer jets. I also re-wired the fuel pump power plug which fell apart in my hands. I am very happy I had 3 extra pre-made ones from a few posts/last Christmas's breakdown. https://bluewireautomotive.com/products/10-x-pcm-ecm-ecu-terminals I have put an order for these in, so I can actually add the pins to the ECU properly. The commodore ECU does not have the pins for Oil Pressure via ODB2. However the ECU can support it if you create the pins and wire them in. So for round two, and somehow attempting to route that into the engine bay through my impossible engine bay grommet is a fight for another day. It's 40C in Melbourne tomorrow, I am half tempted to drive the car with the aircon on to deliver presents to my partner's family and see if it helps with the overheating-on-40C-days-in-traffic-with-aircon-on-only issue that the vents were intended to solve. Do I feel lucky?
    • Yes, while being... strictly unnecessary. Tuning is a bit like quantum physics. You don't need to understand what Schroedinger's equation actually means. You just need to run the computation and accept the answers. With tuning, you just push page up/down until the exhaust tells you that you've got the fuel right. The VE can stay hidden behind the curtain like the Wizard of Oz and you'll never need to know what he looked like.
    • The second part yes, the first part about easy VE calculation is something I've seen a few people talk about online.
