ok b4 i start i du know its a wierd idea but would i b able 2 make a custom plenum and fit the carburetor whyle still running the factory ecu faving disconnected the injector signals and afm and oxy sensor etc so its only function is 2 control the timing and tell me what the engine is doing on the factory dial cluster (i dont like big after market dials)
the reason is to try something diff i want 2 try it on a high comp rb25
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/
its doable with the right tools and carbys.
you'd need to trick the ecu into thinking all the fuel inputs were functioning correctly, eg AFM, TPS, Air Temp sensor etc.
you'd be better off running a microleb or EMS or something
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2884982
I had thought about getting a RB30e decking the head so you get a 10:1 comp ratio. then putting on 6 throttle bodies from a GTR and retain injection
250 for the motor
300 for the throttle bodies
few $$$ for fabricating
you would need to do away with the AFM and work out some way to read air volume like a MAF.
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2894142
Povo pack GQ Patrol used a carbie RB30, see if you can find one and see how the timing is managed
the gqs use a vacum advance in the dizzy, all the fuel injection stuff bolts up to a gq, so i cant see why the carby gear wont bolt up to a skyline. try looking on some of the 4wd forums you should be able to find a carby manifold fairly easilly, ive threw a couple out over the years.
try http://www.outerlimits4x4.com/index.php
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2897036
iv tried looking for patrol parts but cant find any i thought they were single cams which would mean the manifold wouldnt fit a twin cam head also this means that the dizzy has nothing to attache to as the single cams dizzy is recessed into the head and runs of the cam shaft
the reason for the conversion is for the revs but also the sound (iv heard that a carby rb sounds insane) and i also enjoy a challenge
regarding the maf sensor i didnt think it affected the ignition. what does it do?
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2906068
my understanding is if your ingition maps come from rpm vs load (afm value) your going to need the afm to figure out when to fire those spark plugs
unless you change your ingition system to something else or you go programable aftermarket managment then you could get load from something else , tps , map sensor
Edited by arkon
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2908639
so as the air flow increases does the ignition advance or dellay also would it work if i were to confuse the ecu telling it that there is a set ammount (not chanjing) of air entering the engine throught out the rev range (i know hot 2)
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2911716
when load and rpm increase the ecu advances ignition
you could leave it static but it would run like a dog
you could go to a mechanical ignition system (dizzy) if you wanted . these have mechanical systems to advance ignition timing as load and rpm increases usually some sort of manifold pressure advance or wieght system adjusted by rpm
the whole thing is not realy worth it though theres a reason we abandonded carbs and distributors , they are old tech , unadaptable and inefficient .
an rb26 revs to 8500 with ease , how much more revvy do you need ? try and adapt the rb26 head to your n/a perhaps ?
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2911988
its funny coming from an AE86 background to listen to this talk of revs!
doesnt matter how big your cams are, how high your compression is or how many throttles or carby's you stick on it: RB30's wont rev high because of their bore/stroke ratio.
you wanna build a tough, hot sounding NA screamer inline six? Slap an RB20 crank in an RB25
Destroke it to 2.4 and use a twin cam head capable of the revs you want.
(or just use a turbo engine you pansies)
https://www.sau.com.au/forums/topic/154928-carby-on-a-rb/#findComment-2912349
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
