standard r33 series two with pod and 3.5in to 4in turbo back exhaust
made 162 kw@w
after power fc install its got 145kw and surges at cruze and sometimes it cuts out all together
compression is good new plugs etc
so my question is why did i spent 2k plus buyin this thing and getting it tuned ??
any idea?
can i retune it myself?
Edited by juls33
i had the power fc tuned by a wksp
change the ecus over and its normal ????
ecu was the only thing he changed
Its not an issue with the PowerFC itself dude.
If you are not familiar with tuning, i would strongly advise against it.
Did you just change ECU, and tune it?
Nothing else at all?
$1000 for just a tune? My gosh i would be pissed! $500 - $600 is the usual price for a full tune... $450 G.B at J.E.M for a full tune if your in Sydney...
The Apexi PFC comes with a base tune that is made to plug in, start and drive.. meaning if your car is worse then before, its either:
- Poor tune
- Dying part (Fuel pump or AFM)
My advise would be to take it to a reputable tuner, get them to put it on the dyno and diagnose the problem before you end up needing a rebuild.
PM me if your from sydney... got a Dyno Day coming up soon... for $50 its the cheapest insurance for your engine...
Cheers
no im in townsville thats why soo expensive
only one tuner i used to trust :-{
ohh and my fuel economy is very poor 205 km to a full tank (50l)
fuel ratios are spot from the dyno printout
Edited by juls33
If you're looking for help in TSV...try posting in QueenslandStreetScene.com and someone may be able to help you. I am a Stagea owner in Townsville but I am not up to the stage of performance tuning and so am not really able to assist you (The Stag is almost completely stock at the moment).
Hope this is of assistance...
...Chris
For that price they should offer after sales support. Take it back. Get them to drive it and point out what you aren't happy with.
As for the peak power, it's only part of the equation, was the 162 on another dyno or the same one? They don't necessarily read equal.
145 is pretty low, but without a decent intercooler it could have been heat soaked to buggery when the last power run was made.
And with that economy you should make sure they have the closed loop control on. Your O2 sensor could be on the way out but i doubt it
Edited by BHDave
its not the engine it has to be the tune i can plug the old ecu in
and it heaps better and no dramas
162 was third gear peak at 115kph standard ecu
145 was 4 gear 150kph pfc
same day same dyno ?
Edited by juls33
nope standard nothin extra
i drove it with the standard map briefly
not long enough to say either way
i can say it didnt have the holes like it does now
it just seems to lose its place or something and
cut ignition , do pfc have a self diag?
If they didn't disable the boost controller in the pfc, or they set the boost way low [like 3psi or something stupid] maybe..................I really don't know, I'm just wondering if this could be a problem, someone with more knowledge than me may be able to answer.
ive just installed my PFC running the base map un-tuned and its given extra power straight up, theres no way you can go backwards, definately take it back to them, you paid good money for the tune, be firm let them know you want it sorted out cause thats horse sh*t, or atleast get them to find out WHY its gone backwards anyways if you want help with the PFC check out this link its tops
http://paulr33.skylinesaustralia.com/docs/...rfc-faq.htm#end
take it back and ask them, a $1000 for a tune is heaps. i would be happy with $500 at the most. read the pfc faq (in my sig)to find out about your fuel economy and tune types. this will give you some info and help sort it out with the tuner. there is no reason you should loose or power. its all in the tune
Sorry if you already answered this (only had a quick skim)
Have you put the factory ECU back in since this problem came about?
And see how it goes then?
If it runs ok with the stock ECU, i'd be going back to the tuner and asking what on earth they didnt do
Especially for $1000 mate, thats an extremely hefty bill for something if its not right.
For $1000 they should have had the car running perfectly before you picked it up
200k per tank jeez!!! it would be pumping heaps of smoke out.. i wouldnt trust the dyno either,, you cant compare a run in 3rd at 115 and a run in 4th at 150km for starters it should be making alot more power than that w/e gear it was in.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
