Freaking awesome.
Would be great for driving over speed bumps and driving on the kerb :P
Would also be great for high power fwds to keep the front down when dragging.
Edited by Sinturion
Isn't this in the new HSV GTS? As well as a bunch of other GM cars?
Or is this a different system?
Different system.
HSV's MRC uses a magnetic fluid inside the damper, which by passing a current through can adjust its viscosity and hence rate.
The Bose system works the same way a speaker does, but instead of using magnets to move a coil to generate vibrations in the air it works in reverse. It uses a magnets to resist the movement of a coil.
They sound similar, but its not really. In the MRC system the magnet affects the damper fluid, which resists the spring. In the Bose system, the magnets resist the spring directly.
The Bose setup has been around for a while. Motor Magazine did a review of it around a year ago (at least).
Apparently the biggest problem against its adoption is not the unknown reliability, nor the expense. Its the fact that Bose will not license the technology to anyone. They want the OEMs to contract the design for each car to them. They give Bose the specs of the vehicle, and Bose then designs the suspension and ships the finished product back to the OEM.
Apparently OEMs don't want to relinquish the design and engineer for such a core part of the car. They'd prefer to be told how to make the system, pay for the IP, and then implement the setup themselves. With what Bose is asking, they'll only get a little feedback in how they want the car to ride / handle, but Bose does all the setup and testing and just ships a finished product back.
i'd hardly think it'd be possible to get a good final result based purely on using the weight, wheel-base and track specs of the vehicle and feeding the info into a computer simulator. You can only go so far with computer theorizing before you'd actually need to do some real world testing with the car in production spec.
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
