i'd hardly think it'd be possible to get a good final result based purely on using the weight, wheel-base and track specs of the vehicle and feeding the info into a computer simulator. You can only go so far with computer theorizing before you'd actually need to do some real world testing with the car in production spec.
The new A380 Airbus was designed and tested completly by computer programs, no wind tunnels, no prototypes. It is amazing what they can do. Just an interesting point since you mention the real world testing issue above.
I think it's been around for like 20 years or so.
I'm pretty sure GM invented it (or the other stuff that hsv is using) years and years ago in america.
I thought everyone on here would be aware of it existance.
great, every time you drive down the road you'd be like a streetsweeper, picking up old rusty nails and bits of wire.
Start of the trip your car weighs 1400kg and by the end it weighs like 14000kgs....................lol
HSV GTS Magnetic Ride Control
From an owner
The shocks have the fluid filled with metalic particles and a current runs through the fluid, the current can be altered making the shocks firmer when needed. The track setting is always firmer. There are sensors in each shock that can adjust the settings, they read the cars steering, braking, cornering forces every 100th of a second and adjust the suspension accordingly.
e.g. you hit the brakes, the front shocks get a current through them to firm them up, this stops the nose diving under brakes and reduces braking distances. Likewise you corner hard, the outside wheels are firmed up to stop body roll, you accelerate hard and the rear shocks are firmed up to stop the back dropping and the nose pionting up.
IMO the HSV setup is supperior to that of the Bose system. The main advantage of the MRC's found in HSV are costs (far cheaper) and packaging (far smaller). Top of the line ferrari's and Audi's TT along with Caddy's top of the line cars now use MRC.
I want it!
http://www.spikedhumor.com/articles/81312/...ion_System.html
(Note its in French but its pretty easy to get the point).
And I just went and got the Bilsteins and whiteline kit installed :(
This always happens to me :)
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
