Hi,
I've been on this forum a while now under Buzzed, but forgot the psword...so now back as Mike 3:-)
Anyway, I have just aquired a lease car through work, so my garaged GTR is up for sale.
It's a 1996 S1 R33 GTR, silver, stock appearance (5 stock 17inch rims). This car has never had a bingle so what you see is what you get. The car has done mostly hwy driving and as such has done about 105,000km's. It is a very tight example...both the mechanics I have been to always comment on the excellent condition.
Price: 29500 ono including roadworthy. The car has brand new steel wheel turbos and brand new rear disk rotors (thats 4k worth of stuff alone) and will continue to get maintenance as required.
This has been a fun hassle free car to own, a good price on insurance through shannons can also be organised for the purchaser.
Its getting hard to find an unabused GTR these days, so if you are in the market give me a call and I can talk you through the extensive (but still legal) modifications (such as bilsteins, uprated clutch, large front mount, whiteline supsension etc etc etc)
It's got to go, so get the car before the car yard does.
ph:0421 80 9998
Edited by Mike 3
https://www.sau.com.au/forums/topic/155003-fs-r33-gtr-silver-mint/
  • 1 month later...
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
