  • Replies 99
Posted Images
TSM 967 Blue Vy/Vz commodore in rowville area
UIO 923 Gray Crewman ute in Wheelers hill
Great work there mate! Im just wondering if your driving can you spot them out? like can people tell the difference between a normal car and an undercover? I seen 3 cops driving around in this toyota people mover van (not sure what it is exactly) yesterday from the magistrates court in the city.. funny shit cos they look so out of place in it lol
geez those personalised number plates must be a good way to spend money! Nevermind that they're understaffed, plates are definately more important..
Those 'police' plates must have been cheap.
Matt you have to do 4 years of pleb work before you can enter any decent division incl mounted police, TMU etc.
Had an unmarked, old beamer turn up to the neighbours once in thornbury.. dont know what it was... I think it was lime green.. looked like a granny car except for the lights in the back.
Does anyone know what sort of under engine work the cop cars get?
Just curious if they get some toys that are illegal for the rest of us.
Do they do their own maintainence, or would it be outsourced?
I think they do their own maintenance cos i knew this dude that use to fit all the electrics to their cars like the siren modules and lights and all that crap... he told me that the usual for the cop cars is the chip that they get for the ecu's and apparently some sort of steering components. I'm not 100% sure but if anyone knows it would be interesting to find out..
lol yeah that would be to fix the steering issues the xr8s have at full lock.. of course not all cop cars affected seem to have been fixed as yet.
I know hear in ballarat the cops get there car serviced at the dealership. Only certain people are aloud to drive them. And if the cops bring them in with a problem the mechanices must drop what there doing and fix the police car first.
LoL just like a fast food restaurant, free food, first served whatever the fk they way they gets.... spoilt brats lol
I saw them double parked at a local shopping centre last year so one of them could run into the vacuum shop where he bought something... must have been his wife's birthday? lol
Yea that happens often especially parking in no standing zones and going to the cafe and having a coffee, i wish i had those sort of rights on the road.. just paint my car white and put some blue stickers n shit, put some lights on the roof... mmmm sounds like a plan lol
not to mention being charged with impersonating a police officer...
good plan :)
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
