i heard they are heavily modified. then again alot of people talk smack.
LOL yes thats true... i've only heard steering and ecu chip... but yea i've never actually spoken to a cop to ask what they've got done..
  • Replies 99
Posted Images
alan didint u see the (old) roman (times) cop in the middle of the road ushering the ppl away. he is even got a sword brandishing, i can only assume he is saying that move out of the way or prepare to die (u infidels ;-) ).
Heyy... dont be kissing me with those lips... i think.. i'm going.. to be sick... :)
Anyways... dezz do you know what mods are done to the cop cars? :)
From what i've heard over the years they have some form of chipped ECU, and some suspension....they also carry a fair bit of weight with all the shit they add on so performance wise it'd balance out the 'mods' anyway
scomods?
I asked the same thing lol
With the weight in the cop cars i know their sedans have plastic seats at the back... very uncumftable... but yea they would be carrying a bit more weight unless its just a dedicated highway patrol car... now they f*kn fly...
Thats car jacking Roman style for you :O
I've seen that marked GTO Monaro in the city a couple of years ago...actually has the HSVGTO plates on it!
All the Hyundai and other crap cars that sit on the side of the road with cameras...aren't they all Tennix cars as the cops outsource this job to Tennix ..?
' date='9 Feb 2007, 12:39 PM' post='2893553']
Yea i think your right dude... they make heaps of commission on its aswell ey those pricks sitting in the cars?
Theres a pic a couple pages back of that monaro your talking about aswell..
Anyone know exactly what's done to the cop cars?
I know Holden cop cars get a heavy duty wiring loom for accessories like lights and sirens, speedo head goes up in 2kmh increments instead of 5 kmh.
The marked white Commodores get 15"stockies all round with 225/65/15 tyres (wider than standard) lowered FE2 suspension from the SS's models.
Highway persuit cars get smaller 17" wheels instead of the standard 18"inch wheels, the auto can be pulled back from Drive into Second gear without using the button on the gear shift to shift down and some get a shit yellow paint job however most persuit cars are white with an orrange strip down the sides.
As far as ECU upgrades go they are a myth. All servicing is carried out as per normal by Holden dealerships but is also logged in a special folder held at the dealership. After a high speed chase the brakes and brake fluid has to be inspected and/or changed and if a tyre is showing signs of abnormal wear or they get a puncture they must be replaced as opposed to repaired
    • Update 2: Today I'm f**king pissed. Some of you probably saw my thread that I opened shortly after joining this forum, "urgently need expert/experienced opinion", in which I discussed the possibility of a porous RB26 engine block which I also found hard to believe. Currently both turbos are out since the shitty braided line that was installed by whoever fitted the GT28 turbos leaked oil onto the exhaust. Today while working on the cam covers to put new gaskets and half moons in, I cleaned the side of the engine block with brake cleaner. Some time later I saw that it was still glistening with oil or coolant so I dried that off. But it was wet again shortly after. Verdict: I'm royally screwed. What you can see here (hopefully, despite shit resolution), circled in red, is a crack above the turbo oil feed. Extent is a few cm long and basically goes from #3 cylinder wall to #4 cylinder wall. It slowly lets coolant through, even without any pressure behind it. I am absolutely dumbfounded as to how this crack even formed, especially since it isn't along the cylinder as it usually is but rather a horizontal crack. Probably a few cm in length. Not sure on how to deal with this issue right now. Most likely, the only true fix is a new engine block, and even a relatively well done temporary fix requires at least a full engine teardown. Neither of those really fit my timetable right now, the car has been in my buddy's garage long enough as it is. I'm open to suggestions, but I'll be looking into ordering a new 05U block soon so I have one ready for the coming year, or whenever the current block inevitably fails fully. (Most likely once the crack reaches one of the frost plugs) I think it'd be a waste of money and time to rebuild the engine with this block. Oh and I found a rust hole on the side pocket of the trunk, which someone covered up with sealant goop, a piece of number plate and bodywork filler. Fun times. So far for every issue we fix we just find a new one that is arguably worse.
    • I have not found this no. I put one back on a couple days ago with no drama. I agree they are tight, but no need to remove anything.
    • That is gates blue racing belt
    • Anyone found gates blue racing to be extremely tight/ almost impossible to install without moving the exhaust gear
    • Hello am apex am new here and also thanks for helping registering the forum
