Hi all!!
Just thought I'd let ya's all know that I'm moving to Brisbane next week (currently in Adelaide).
My wife and I will be staying with my parents initially (what fun) and hopefully able to rent a house and have our furniture moved up within a month or so from now...should be good.
Great job opportunities in brisbane, which is the reason for moving...if anyone knows of any junior C++ computer programming jobs at their workplace please let me know!!
Looking forward to the next brisbane/gold coast meet/cruise...
Cheers,
Steve.
https://www.sau.com.au/forums/topic/155029-goodbye-sa-hello-qld/
WOO HOO! Another to bolster the QLD ranks, everyone wants to move to QLD, you know you want to! :P
C++ eh, I might, but it would be here in Rocky..............?
hmmm, i'll be in brisbane suburbs but thanks anyway. In any case I'd be looking for a junior role only as I have no formal qualification in programming but have 2+ years commercial experience in a programming role. I will be taking courses once in brisbane to fix up my lack of certification(s) - looking at doing Java as well and likely SQL to give me some good skills to start with. Kind of looking forward to it...
EDIT: I just want to also add that my commercial C++ experience was quite structured and required a good understanding of professional programming guidelines. 2 years is a lot of programming, and quality of code is always essential in any business software. So yes I am self-taught but I do have very good business programming discipline, and can easily adapt to different coding styles. :)
[/end of shameless self-promotion]
and yes, QLD is a great place to live - from what i can remember - I lived there until I was 12 (family moved to adelaide then).
Edited by pixel8r
Sounds good, so where abouts in Brisbane are you moving too? We need another Stag to replace robs!
about 30-40 mins south of the city initially - thats where my parents live.
We'll be moving into our own place soon after we get jobs and enough money to pay for a removalist...but not sure where we'll be living...most likely south. >_<
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
