Just looking into buying an Eboost2 controller and some new gauges.
I've hit a wall deciding whether to get a boost gauge or not as Im not sure whether or not the Turbosmart Eboost2 controller has an actual boost gauge within its display. As I obviously dont want to have a separate auto meter boost gauge next to my eboost displaying the same info when i could have a voltmeter or another gauge etc. And I need to buy them at the same time as I am making a custom panel to mount them in my dash for a factory look.
So my question is, to anyone that knows or has an Eboost controller, does it have a boost gauge which stays on while your driving, working like a digital boost gauge? Or does it just tell you what the boost is set at?
I have tried ringing a few autobarn stores which sell them but nobody seems to know what they are on about, just giving me ummms and aaaahhhs.
https://www.sau.com.au/forums/topic/155067-eboost2/
This might help you a little if you already havn't checked it out, it gives you downloads of instructions which should give you some insight...
http://www.turbosmart.com.au/index.php?id=42
Yeh i had tried that before originally posting, the PDF files are corrupted and wont open.
https://www.sau.com.au/forums/topic/155067-eboost2/#findComment-2885027
    • I am using Motec M150.  I am not working on the car myself actually.  My workshop is giving all these info, they are quite reputable in the industry and are very familiar with Motec and RBs and have done a few big setups with VCam and single turbo on RBs.  In fact, they built and tuned my engine from day one.  But they are stumped with my engine at the moment and cannot work out how come the compression is so low with the VCam. They told me that they have now swapped in some Kelford cams (without the VCam) and can achieve around 130psi compression and the low end torque is better, but now the engine is doughy as.  It boosts and peaks at more than 1000rpm slower, with twin HKS GTIII RS, it doesn't get full boost until over 5000rpm. I have always thought the VCam was a bit disappointing at the low rpm. To a point I had to ride the clutch a fair bit to get up a small hill from stand still.  That was when I had a clutch.  Now changing to a 8HP, I don't have that luxury and this problem has become a major issue. I am beginning to think the VCam never work since the day it was installed.  Maybe it was just sitting at the most advanced point, that is why it went good at top end but very ordinary at the bottom.  Therefore, with the help of the Holinger 6 speed and paddle shift, as long as it was moving, it drove pretty good.
    • yeah, there's a country that recently started importing Skylines, I blame them.
    • I don't have a printer, but could at least attempt to make a printable model.
    • If you do make them, im sure you would have a number of buyers.. Every GTR I've been in have rattly door windows
