Hi Guys..
Just before new years a friend and I installed my fmic.. its a R34 GTR front mount..
Ever since then when the turbo spools up I get a very high pitch wistle sound..
As my friends would put it.. it sounds like a truck turbo.. Its extreamly loud!
Any Ideas on what it could be??? All the piping is clamped on pretty tight.. and im not losing any power..
I just dont want my turbo blowing..
Cheers,
Corinne
z0mg turbo?!
Umm.. whistling would suggest that perhaps it's either a gasket or one of the pipes leaking air. I'd be leaning towards gasket
Check the blow off valve as well if you're running one
z0mg turbo?!
Stock bov.. Havent touched any of it except fm and exhaust pipes.. which it only started when the fm went on.. Other then that my mechanic does all the engine work..
double check all the pipes and the intercooler for cracks
Sounds like a boost leak and it could even be a cracked pipe or intercooler or lose clamp or even a hole in a hose joiner.
does it sound like a vaccume cleaner thats blocked?
smoke test.....how about using the decarboniser? $20 from subaru. i had the same noise and when ever i used the that de-carbon spray thingy the smoke would come out of my exhaust manifold. broken studs and buggered gaskets. all fixed and problem solved.
oh no. you need to tighten up your turbo. the bolts are loose. and it will fall off. well not literly. but if you get it now. you can save the gasket.
DAVVEEEE DONT TELL ME THAT! *cries*
do you mean the kettle whistle noise?
mine does that, since the fmic went on
its a crappy chinese core and it just whistles away
Yesst thats what it sounds like..
But mines not a crappy chihnese core :( stock R34 gtr cooler *sigh*
how is it mounted (in terms of the front bar)
my front bar (series 2 one) was cut up a fair bit
and was a bit of a hack job install
i think the whistling may be coming from the cutting
and air passing arround the core / air ducting etc..
the easiest way to check drive along at say 50km/h
clutch in, let the idle engine
if you can hear whistling, its probably the core / front areodynamics making it whistle.
my 33 whistles quiet a lot, very audible
somewhat amusing as well
its the kettle car
its the kettle car
Nope it wasnt hacked at.. mine check all clamps etc first..
    • I know mentally you're set on the ATS clutch but honestly I'm a big fan of the Nismo Super Coppermix Twin. It's much cheaper and in some ways I think it's a better design for a street/circuit car.
    • Just checked in first post and you should be able to bring it home November this year, right? I'm amazed you made it through four years of this. As hard as it feels now the rest will go by in a breeze in hindsight, I'm sure.
    • Realized I haven't been back here in a while. Still here, still alive, still waiting for the car.  I went back again the only time last year from Oct-Nov for R's Meeting and drove it around some more, including a few laps on Fuji Speedway(in the wet, sadly). The car still feels good, but have a couple small things to address. I've been getting more parts but have slowed down still, and most of the bigger purchases are now out of the way. I find myself getting impatient more and more when it comes to getting started on this project; it's quite hard for me not being able to really dive in and start making this car my own because it's halfway across the world. At times it doesn't even really feel like I own one of these. Haven't really been motivated or had the desire to document the last trip on here or social media for, well, reasons... but here's some pics...it's also still alive and well as you can see: I've narrowed down to the last large part purchases(anything over $2k) before the engine build to be: 1) Ohlins Road & Tracks 2) ATS Twin Carbon clutch 3) Endless BBK with some custom options and 4) Kansai Service carbon driveshaft I don't think the budget exists for all of these this year, but I'll try for one or two items I think. Though, every time I look at my spreadsheet I sigh, shake my head, and get depressed just that little bit more.  'til later.
    • It's a stunning location!  I've been to NZ twice but haven't made it to the North Island yet.  Definitely on the cards but the South Island is hard to tear yourself away from too... Looking forward to see what you can wring out of it once you can get it to hold together!  Be awesome to get a low 11 or even sneaking into the high 10's pass out of it.  That's a bloody quick car that most people will never experience in their life.  Enjoy!
    • Nominally yes but I’m not really at that stage yet. Outsourcing to Japan is also a relatively good deal at the moment because their currency has devalued much more against the USD.  You would assume this but a lot has changed from the pandemic. Mechanics are in short supply and demand for fixing old cars has gone up from the cost of new cars. 250-300 USD/hr is not an unusual shop labor rate in California and you’re paying that regardless of whether the guy is competent or not. Coworkers have been quoted 3000 USD for a water pump and thermostat at a dealer on an N54. Oil changes went from ~75 USD to 150 on fairly normal cars like Civics. The cost of the oil and filter hasn’t even kept up with inflation.
