Does anyone know much about the tests that you get done at Botany or Penrith?
Mine is booked in for Botany in the morning and I was wondering if leaning the PFC off heaps would make it better or worse... Anyone have a Idea?
Would using different fuel make a difference? Should i use BP98 or Mobil Synergy or Optimax 100 or even the E10 fuel thats available?
Has anyone passed this test with a Power FC with huge injectors and a topmount gt35r or something similar?
Would be good to see how bad or close my car is before i go spending lots of money to get it right.
I got stock cams and cam gears and just put a Xforce highflow 3" cat on it
Any ideas welcome!
Edited by Guilt-Toy
https://www.sau.com.au/forums/topic/155081-emission-testing-modified-skylines/
  • Replies 185
Depending on what year it was made, emissions change , you will have to pass the emission test for the time your car was made .
If its post 95 my guess is you will not pass unless its very close to stock .
Edited by wrxhoon
any ideas what fuel to use Jerry ?
I would use the 100 ron from Shell, because it has ethonol and it may help.
The last time I took a car for enissions test , this fuel wasn't available so I used normal 98 ron.
If you can get your hands on a new ( or near new) compliance cat , i would use that as well .
To be honest with you , I dont like your chances with your current set up. If I remember correct your car is 95 model and that mekes it harder, earlier models would be slightly easier to pass.
Good luck and let us know how you go. Give me a buz if you like as I have a tip fpr you but I dont want to put it on here for obvious reasons .
This is just the first step to see how much my car is out before changing anything to pass for engineers certificate.
No defects or anything so im being pro-active instead of re-active atm
Give Matt (aka Hitman) a call. I think he helped Mona sort out an emissions test last time.
Are you going for a test just to check, or is it for engineering cert / EPA?
it kinda makes sense to use a better burning fuel.. maybe even advance the timming abit so that it burns all the fuel? retarding the timming would be the reverse? this makes sense in my head duno bout on paper.
well the question for me now is should i use the optixmax 100octate fuel thats 5% ethenol or use this e10 blend stuff that is available thats 10% - the 10% will burn a better emission but its only 95 octate and i wont be able to run it as lean with the same amount of timing.
What to do...
This is what i found about e10
Emissions outcomes for E10
In general, E10 can be expected to yield reductions in the following emissions:
carbon monoxide (CO);
exhaust hydrocarbons (HCs);
particulates;
oxides of nitrogen (NOx), (in some circumstances);
greenhouse gases, depending on the ethanol production process; and
known carcinogens, such as benzene.
However, some increase in other known carcinogens, such as formaldehyde, can be expected.61
So it does decrease nox which is one emission they test for.. now to look on the site to see if they test for formaldehyde - whatever that is...
particulates;
This is what they test: THC, NOX, CO and CO2. They will do 2 runsa the first is a warm up run , most cars will fail this and then they do another run.
Cheers Jerry..
Thanks for your advice its all sorted... and i decided im going to run the shell 100 because its the best of both worlds.. its got 100 octane and 5% ethenol.
I really dont think there is much chance of passing but i need to start somewhere.
So no one here has passed there modded skyline with intercooler / plenum / top mount and 700ish cc injectors with a power fc and gt35r before?
Found this on the gov emissions site. which basically says that the NOX level is increased which is what most skylines fail on. So i am going to run normal BP98 fuel or Synergy 8000 after i do more research on the 2 i will decide.
Hydrocarbon emissions decreased as higher percentages of ethanol were added to the fuel:
at 10% ethanol, HC emissions decreased by about 18%;
at 20%, HC emissions decreased by about 22%; and
at 40%, HC emissions decreased by 45%.
CO emissions were consistently lowered as higher levels of ethanol were added to the fuel:
at 10%, CO was reduced by about 18%;
at 25%, CO was reduced by over 30%; and
at 40%, CO was reduced by over 40%.
NOx emissions increased substantially with ethanol volume:
at 10%, the NOx emission increase was about 10%;
at 20%, the NOx emission increase was about 14%; and
at 40%, the NOx emission increase was about 20%.
It should be possible to get it to pass, P.S. make sure your closed loop is enabled on the hand controller. They dont do power runs or anything like that, its all mid/low throttle stuff. you will need to have the cold start/warm up enrichments well calibrated to pass though. When i had a car tested, they practically made it pass by telling me where to make the adjustments, and then did the second test. PS when i worked at chiptorque, we got the horsepower hero VK commodore with 440 rwhp to pass, although the cats almost killed the motor.
Closed loop on my car made the thing run rich as all hell!!! it was running into the 13's etc etc
This is a good idea though if it does fail i will ask them for a run with closed loop on.
I was going to suggest the higher ethanol content, run low and fill up with an emergency 5 bottles of Recochem metho 95% ethanol. Do the test, pass with flying colours, quickly get to a servo and fill up with 10L of fuel, run it down to dilute the ethanol, then fill the tank up per norm.
I can't see it hurting if done over the course of a couple of hours, I've done this with a corolla with a 4AGE, I ran close to pure ethanol in an emergency and it actually ran beautifully.
failed! but it was a good result for the first run - its not even twice over the limit for nox - nox was 3.45 which should be no more then 1.93 and the THC was 0.99 when the limit is 0.93 and CO was 2.4 where the limit was 9.3
So the engine is running too lean and its very close to passing. I am thinking about doing some more tweaks and give it another go or get my mates dad to tune it with his 5 gas sensor
ohhh and my car gets 11.9 litres per hundred economy!!! thats pretty good for 400rwhp!
Edited by Guilt-Toy
He also said that my car has some kind of vapor leak - and you can smell it too so i gotta get a smoke test done to fix that because in the room it was reading 23 where when there is no car in the room it should read 0 and a total new stock car reads 1 - 2 so something is leaking vapor somewhere
Very interesting....
And great to hear. :laugh:
I can often smell a little vapour from mine. I have no idea where its coming from.
Possibly from the seal in the boot where you remove/install the fuel pump as it has been out a couple of times.
Maybe old fuel hose near the petrol tank? If I place my nose up against mine I can smell fuel. :S
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
