Thats the thing, they are legal.
Exhaust baffles are not legal, yet Ferrari's etc are allowed.
Its a fair load of crap.
I've been reading a lot of the DOTARS website and other ADR/Emission laws/information etc.
It doesnt seem hard to pass... so the Vic laws must be some pretty rubbish filled stuff, or they just want you ot think thats the case :D
  • Replies 185
wow im surprised they let you clear given the modificaitons done
epa in vic wouldnt let that pass for peanuts
as soon as its aftermarket anything pretty much no chance
:D
Am..........no
Just like any state, you make a modification/s that is untested, then yes they are illegal. You get an emissions test and prove that the car still complies to the emissions, for that year (ie: 1995), then they will pass. Unfortunately each test, in VIC, costs $1500, so if you fail the first time, that's another $1500 to test again.
Just ask Mav. He had lengthy discussions with the EPA officer, who commented that cars with bigger turbos, inj, power, etc, than his car (280rwkw), passed running ecu's like Pfc, Wolf, Motec, etc... EPA even passed Mav's car with the Greddy plenum and fmic, without any testing required.
EPA is not the pack of a'holes everyone makes them out to be.
PS: Congrates Guilt-Toy!! That's an awesome effort :P
They are a pack of mongrels. Its pretty much, any mod... BANG defected even if its making the car run better than it was before.
Even if you DO get tested/approved, the Police can STILL report you even if you've been cleared 110%.
You could go there 10 times a week for all the Gov't cares.
The rules and reglations (in vic) far go anything that any other state has for no clear or apparent reason. Other than power abuse towards the general public and making it impossible for the common punter... and a bit of revenue raising on the side of course.
Why should it cost me 10 times as much for a test on one state compared to another?
Why should i be able to cross a mystical line in the sand and my car can suddenly be cleared/tested where if i cross back the mystical line, suddenly im driving an illegal car?
It does not make sense, but i intend to make good sense of it :D
What AL said is correct, its actually not that hard to pass the emmissions test in vic. Most of our cars would pass if we had a compliance cat and a good tune (not too lean), I was even going to get my s15 tested.
But when i got quoted $1700 and if it failed you HAVE to go back and pay for another test, it was not worth it. If you have the cash you can do it. BLKCRX (james) of CRXaustralia and Hondata fame passed no problem with over 300rwkw from a 1.6l delsol CRX. And thats on a car that had no turbo to start with.
Congrats GT, i was wondering if you still have your EGR hooked up, as under vacuum conditions it injects exhaust gas into the inlet to reduce combustion temps, specifically to target NOx levels. Perhaps if it is hooked up. then you would be able to run leaner mixtures? Also the charcoal canister it there to remove fuel vapour from the tank especially when the tank gets hot and the fuel expands/boils. this is to prevent the pressure forcing raw fuel vapours from going into the atmosphere. Not trying to dampen things, but although it has passed emmissions, the engineer is obliged to check that all these, and pcv/breathers are fully functional, although most engineers dont.
Im pretty sure the charcol canister is all hooked up correctly.. i hooked it back up again last weekend and not sure about the pvc valve.. i think it is all still stock as i run the standard bottom half of the plenum with the plazmaman.
EPA do not issue defects :D
The cops are another story.... But if you get your car tested, pass emissions, get engineered, etc then you can take the defecting officer and his precenct to court for harassment; it has been done and won before. Then the harassment will cease :(
It does not make sense, but i intend to make good sense of it :)
EPA do not issue defects :)
The EPA issue a notice, defect, whatever you wanna call it.
Does it really matter what its called? We all know what it means
cheers dude.. Autronic is another ECU that has been known to pass emisions so you should be able to do it to... my car is not legal just yet - i need to get a engineers certificate to finish it off which is comming very soon. but its a good start and something to show mr police man if he gets nasty about it.
nice work dude. do my autronic kthanx :(
hahah nar must feel good to drive around knowing its legal. ive only got halfway there.
This is how it works:
Cop pulls you up ancd decides to send you to EPA for ammisions test, you have about 4 weeks to do the test, if you don't go for the test then they cancel your rego. If you do the test and you don't pass they cancel your rego just the same . Same as any other defect .
hey guys top work. This is the type of thing we need to keep doing great work. I think that there is a cat that reduces the amount of NOX its called a 3- way cat, is this what you mean when you say compliance cat.
Cheers Matt.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
    • It's a place for non car talk. There's whoretown which is general shit talking. But also other threads coving all sorts of stuff(a lot still semi car related)
    • Looked it up. It sounds so expensive lmao I'd rather not. Awwwww but I just love that sound
