hey mate
Yes i did lose quite a bit of power. I still have the same cat on since the test i think its 2 and 3 quarter inch.
not interested in power atm.. i gotta upgrade the fuel pump and retune it on boost to go for around 350 - 380rwkw so I am going to invest into a 4" high flow cat which will cost around $400.
For now i will go back to using my xforce 3" highflow
Is it restrictive?
Did you loose much more power when you used this cat?
  • Replies 185
IF it does cost that much in VIC to get the test then you should look for a tuner that has a 5gas sensor system and pay him to tune it so you can pass the test the first go.
i cant stress how important it is to get a HIGH quality cat that has been proven to remove emissions. Catco is the way to go - i believe there is one that is a little better.
What was the procedure for the test? What did they do...
Max 4 min test on a dyno designed to simulate various load conditions (eg normal driving). Will stop earlier if it has clearly passed/failed the test, otherwise will continue for the full 240 seconds (hence the name).
The full 240 second test simulates driving over a 3.1 km course with an average speed of 47.3 km/h and a maximum speed of 91.2 km/h.
wooahhh.. nice answer :(
but they never stopped when i went the first time and leaned it off and the nox went up like nothing else :) they kept going and gave me a print out.
if you look at the sheet that i posted you can see the different gas's and the speed that the car was going as well. the top line is the speed the bottom is the emissions - as you can see its very low on bottom one. i should scan my first test and show you.. its pretty interesting the differences between the 2 tunes.
They drive it for around 30 seconds and then they come to a complete stop then keep going and then get up to 90ks an hour and cruise then come to a complete stop.
I think a stock turbo r33 would go into boost - so maybe disconnecting the actuator might help ;)
UPDATE !!
I passed the noise test today!!! just scraped in by 1db :)
got 87db at 3500rpm and 89db at 4000rpm
So now its smooth sailing to my engineers certificate !! just got to brace the huge hole i got the 3" intake pipe going through and take it back and pay my money!
UPDATE !!
I passed the noise test today!!! just scraped in by 1db :ninja:
how have you been advised to do this bracing?
  • 2 months later...
Congrats on passing the emissions testing!
I wonder though, what the point of it was? You say that you pro-actively submitted your car to these tests because you "wanted your car to be legal"...
But you say that you are going to replace the very restrictive catco cat with a 3" and possibly a 4" cat. That will render this passed test obsolete and irrelevant? Are you going to keep this tune, or are you going to lean it out again for greater fuel economy?
Fantastic job building and tuning your own car to a degree that you can control gas emissions to such a fine line, but I have to wonder what the point is, if you're just going to continue modifying your car and render this passed test useless?
The reason i did this was to get my car legally engineered. The way it works is that you must get the IM240 test to get a engineers certificate to prove that the modifications you have made ie - intercooler and plenums and exaust manifolds and injectors and ECU etc etc do not change the emissions of the car.
I have heard that EPA can do road side tests and when they do the legal limits are different to what the RTA is - i have heard that the RTAs IM240 is twice the limits as the EPA so if you get a good high flow CAT the EPA tests will pass without any issues.
Oh and i have not touched the cruise tune since the testing at all as it is fine as it is and still gets good fuel economy but not as good as it was.. bit of a trade off i guess.
Edited by Guilt-Toy
  • 5 months later...
  • 1 month later...
Good to hear is all clear..
I got detoured to an epa station last night.
They got me for;
* Exhaust (noise)
* Air Filter (induction noise)
* non-standard intercooler - turbo
* adjustable fuel pressure regulator
* catch can has a filter on it
Can anyone give me some more advice as to what i should change or do.
Car - 1990 R32 GTR
Current Mods
* PowerFC dejetro
* cams
* Single hi-mount turbo
* bigger fmic
* airfilter
* exhaust
* Fuel pressure regulator
* External Gate
* Catch can
Your help would be greatly appreciated
Dave
    • Hey guys I have a 2001 Nissan stagea vq25det, I don't have any engine lights and not really any issues running but I was curious to see if I could use my obd II scanner to find anything that was hidden and I plugged my scanner in and it just said "Low voltage cannot scan" does anyone know how to fix this or what this could be?
    • Sadly we have something in common, our Skyline's like blowing up electrically 馃槩
    • So, no videos, but, the FAB9 Elite manifold and 68mm Bosch throttle bodies are in stock, but, not the rear part of the air box The FAB9 rear airbox thingie is made with a 3" intake pipe, to suit the 3" intake pipe size of a 68mm throttle body  When they get some more in stock is currently unknown as I'm waiting for FAB9 to reply with a ETA on resupply, my assumption is they outsource their plastic printing stuff to "china", and with the current "tariff war" going on in 'Merica it could be on hold for an undisclosed time Should I pull the pin on the Intake and throttle body, and wait for the airbox?????, that's what I'm thinking... 1. Would the standard 2.75" OEM intake on the air box really be that much of a restriction compared to the 3" naturally aspirated?????? 2. If I don't get the 3" FAB9 airbox fitted at the same time as the intake and throttle body will it need a retune, when/if it eventually turns up?????? As I'm impulsive, to a fault, decisions will be made within....."what's the time now"???....let's say 12 hours......LOL
    • yeah its just so expensive nowadays and its easy to lose motivation very quickly when you start adding up the costs. I acquired the car from a collector in Melbourne and was lucky to get the opportunity to buy something already completed.  I looked at a proper resto and your paying over 300-400K for a proper one (nut and bolt) so this one to me seemed like a much better option! Car is in private storage and for serious buyers, welcome to come see it/drive it in person (photos don't do it justice).
