Originally posted by franks
wow! that is kik-ass!!!
:uh-huh:
yes, very good price.. is that the heavy duty organic.. thats what I got (around $500) and i am very happy. Only problem is with my 205 tires, the clutch grips so well if i changed too hard from 1st to 2nd, it just spins out to the red line.
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
