yeah i cant really see myself spending over sorta $16k for the car alone... thats why this was good, ill be paying about $1800 for insurance and also stamp duty is gonna take the price beyond what im happy to pay really...
im almost at the point of getting a VT wagon with a kit and boosting it, but i dont really like the look of them... i just dont want a slow crap wagon when ill be driving 4 people and a drum kit around most weekends. (yes i tested it will fit in a stag.)
so importing in general is good, but conversions are something to stay away from?
there is a nice white one on the site that i would be happy with, just its more expensive
what do you think of this (he said the stone chips will pass roadworthy)
http://www.j-spec.com.au/list/index.php?ID=9211
again, after 2 minutes on the phone to the bank he was trying to give me a 15k loan, so i dont have a problem there... i just wanna get the right car... and i have a few grand banked already for unforseen hiccupps.
If its the car I'm thinking (and everyone else) of. Bayside blue with a kit, wheels and is parked on a street outside a house or something. If thats the one its been hanging around for AGES now. Seen it a few times on and off at Prestige and J-Spec. Looks great and contemplated it my self. But its a huge risk. Technically it CAN'T be complied as it was never available as a manual (despite the series 2 or the 260RS having the option). But the only way I would do it is if I PERSONALLY knew the workshop doing the compliance. Not go by a spoken guarantee of the broker (not saying anything bad about either of the brokers I've mentioned at all either as I've heard a lot of good reports about both) BUT if they knock it back you'll be up for a lot of money. Put simply by the time it was completed (if or when that is, depends how deep your pockets are) you'd of come away cheaper importing a good example 260RS and then still could of spent money on it here in Aus. If you still don't understand where i'm coming from ask the Guys on here that have done the conversion, parts labour etc (although the Auto gear would be cheaper but harder to obtain) then double it as your basically converting the converting back. Just not worth it. Series 2 manuals are becomming cheaper now (espically since the M35 is now available), but are still a little harder to find. It would be worth the wait though, and a newer model too.
Still its up to you, but I'd say this is the reason the car has been hanging around for so long now.
Yeah that makes a lot of sense man - as hard as it is to listen to, i was really set on this one... >_<
Yeah that makes a lot of sense man - as hard as it is to listen to, i was really set on this one... :(
yeah but i recon your getting a shitload more car if u go the white one i love my series 2
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
