  • Replies 96
yeah im working on it unfortunatly money caught up to me... should be rolling soon after the 15th of march...
but ill get some shots tommorow after i finish the custom acrylic Mirror mounts i made topped of with Final Konexion CF Mirrors... looks so sweet...
quick shot of the mirrors....
took us an hour to find Final Konexion... but they were worth it..
not done yet still need some silicon to seal the plate.. to the car better......
Note: Copyrighted since 1/3/2007: so "Hella Flush" doesnt jack my shit... hahaha
Edited by 4DoorWhore
"what colour blue are you going again? is it like huddys blue?"
your point would be correct if
1. Huddy was able to get me any other colour paint other than his blue
2. for the same price as he could get blue for me (4lt for $100)
sorry but I could see a point in getting another colour and spending an extra $500
phat mirror's never been a real fan of that style but your set look the best suited Ive seen
I gotta say dude, that is one hell nice cef hey. Lot of work gone in to it for sure. Cant wait to see some nice pics done when you have it all done. Good work.
coz theyre not cheap copy ones which are point ends... and some weird shape which are chunky with very long stalks
did you use s13 or r32?
spot-on dude... glad to see you actually know the difference... yeah the cheap ones use black metal of some kind and plastic mounting points. and the FK mirrors use all spun aluminum.
actually Final Konexion sells them for universal application so just make your own mounting plate and your good to go... you can use CF, Graphite, etc. or like i just used tinted acrylic cause its cheap you can get it in just about any color and i think the best choice. cause i couldnt find any CF stock around for a reasonable price.
Mini update to build suspense woooooooooooooo.....
went to town preping the engine bay... getting it ready for next weekend when we change cross members and drop the damn motor in finally...
fun day... Nick got backed into.. not funny but not serious...
Corvette on SSR's
Pressure wash and scrub time...
Thank god it was an NA man it was easy to clean...
Painted wow that didnt take long at all...
did a little bracing, why not...
engine in! haha powerd by underage girls haha just playing shes legal... push dammit!!
wrapping it up...
next day, RB on Bottom, SR on top....
with lines swapped over... i used the rack to cause it was nicer... but there both identical...
Nothing RB left on the car now...
Corvette on SSR's
wrapping it up...
how did u bracing it ? Just drill the holes and use the pot rivels ? it is really help bracing ?
Last pic with the front bar on is shit hot.. Pocket bikes FTW!
dats so random :laugh: , wat u get a new 1?
Dan I think Nick is the spray painter ;)
and y aint he on da forums ? :glare:
Edited by Dan_J
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
