hiyall
a friends rb26 died , a valve hit a piston or something . hes rebuilding it . head has already been completed but bottom end is still apart . its going to have forged pistons and nothing else .
what as a minumum is a good idea to do to the engine now while its apart . its not going to be a HP monster just things that should be upgraded now as you might as well while its being built anyway
i suggested n1 oilpump
metal head gasket to lower the cr a little bit ?
any suggestions welcomed
thanks
https://www.sau.com.au/forums/topic/155157-basic-rb26-rebuild/
just usual street duties as I said , occasional amature drag , track work nothing serious
its not going to be a high hp motor , it will probably get a pair of 2860-5s like i have for my r33 . its probably about 350rwkw max but it would be good to get some reliability and strength
its basically a dead rb26 thats getting rebuilt to fix it rather than performance , but I thought you might as well do some stuff while your there to fix factory deficiencies more than anything
Why?
What deems that a requirement?
arkon - whats the use of the car?
I suspect just usual street duties?
Its says any suggestions welcome you do what you want with your engine but tomei baffles dont cost much and can help keep oil around the pick up. I only have 2530s and have larger sump and baffles. Do as you please that is one of my "suggestions" i didnt say it was a requirement.
Brad
PS i also used ACL race bearings and need the JUN or copy Crank collar for N1 oil pump if its a R32 crank.
That's a bit of a contradiction. You said not high hp, then 350rwkw? 350rwkw is not cheap.
Perhaps you'd better let us know what his maximum budget is, then we can let him knnow what he can AFFORD for the price, rather than what is NICE since the engine is open?
wow! just 350rwkw!?
So you want a 500HP road car and its not high HP!? You'd be sinking some serious $$ into this car to keep it running with that much power.
am incorrect in thinking a pair of 2860r -5s with cams would be about 330-350rwkw . probably closer to 330 i guess
and there seems to be a lot of unopened rb26s doing that in the rb26 turbo upgrade thread
by not high hp im thinking more 1000hp twin to4z or something along those lines
Without dragging this off topic could someone be kind enough to list every single part (and quantity of each) required for a bottom end RB26. Their are plenty of us that drive these cars but don't know the absolute minute technical jargon and would value this information which im sure would help the OP in his request of info too.
Edited by benm
1 crankshaft
6 connecting rods
6 pistons
6 piston pins
6 piston pin circlips
6 main bearings (6 sets, 12 pieces)
1 thrust bearing (2 peices)
6 rod bearings (6 sets, 12 pieces)
6 oil squirters
6 top rings
6 2nd rings
6 oil ring spacers
12 oil rings (6 upper and 6 lower)
1 front crank seal
1 rear crank seal
1 rear crank seal housing
2 oil restrictors (top of block)
14 main studs
12 rod bolts
1 oil pickup
1 oil pump
1 water pump
1 sump
1 tensioner
1 idler pulley
1 harmonic balancer
1 crank timing gear
2 sump baffle plates
12 big core plugs (unsure on exact number of plugs???)
6 small core plugs (unsure on exact number of plugs???)
then u have the external bits like alternator, etc but i doubt u need to know all them :D
i probably missed some things but thats about it from memory
im not saying all these need to be replaced, ive just listed all the parts in a rb26 bottom end
Edited by CruiseLiner
    • My extinguisher mounted like this unscrewed a little (Maybe from the chair sliding forward) and dumped a bit of white on my mats. I'll need to get a more narrow one for future.
    • I totally couldn't do the whole kids taking up my life thing! 😮 I find it bad enough doing 45 hours in 4 days, and then fitting normal adulting life into the other 3 with no kids! As for my mates race cars, they're AMG C63 setup for production racing. The original is what has just been stripped and a brand new shell built. The original is then going away to have some panels straightened, then it will be put back together again. Then there's a third that will shortly head off to have a roll cage put in, then build it up too. And potentially a fourth to be built too... Oh, and he has two Renault Clio D class production cars, ha ha. And when he's not racing them in the Australians and QLD production championships, he's been racing one of Chaz Mostert's Lamborghini's in GT4. They just won GT4 at the 12 hour in the Lambo. We're pushing to finish the new AMG as it has its first round (and potentially its first shakedown/outing) in under w weeks for Round one of QPC, and that round is really the shakedown to make sure it's all good for the Bathurst 6 hour, which I'll be at too. Ha ha ha Working on my project is different to his, I slowly tinker and work ways to make things happen on a shoe string budget. Hes in a good position that he has a massive workshop full of parts and tools, ha ha. He also looks after me. When his air compressor died, he just needed it working, so bought himself a new one and gave the old to me. Sand blaster unit too, and a 20t pressing. And pretty much all the shelving in my shed too as he upgraded all of his (the stuff he gave me is the expensive black Bunnings heavy duty stuff)!   I enjoy working on his stuff. No decision paralysis, and anything that's needed parts wise is just there. Plus, then I get to be hands on at the track in real racing, not just club day stuff.
    • I know which one I'd prefer to have in my garage, and which one I'd actually drive as intended
    • Yeah mate, no probs. Just swap the email addresses?
    • I definitely agree with you there - I never click on content for cars I would never ever be able to get or compete with/against/be seen next to. Seeing a MX5 compete with a FD RX7 will make people upset though, for sure. Even in 2.5L Turbo form which is pretty grass roots. (or at least as grass roots as classic cars can be) Yes we're all classic car owners now.
