Hey peps, i am new to the forum cause i am having a b*tch of a time getting some straight answers from workshops. Story goes i have an 4 door r34 skyline with the usual mods (boost controller, bov, fmic, 3" turbo back exhaust, aapexi safc2) running 8 psi of standard turbo (175rwkw before fmic and afc2). The problem i am having is that since i had my 100000 service the car runs rough like it has dropped a cylinder, engine light comes on the dash and so does the tcs & slip lights. Almost sounds like a wrx is the best way to describe the sound. the service included timing belt and new plugs (iridiums). i have had the afm, cas, checked out and they are spot on. can anyone help?????? this has been going on for three months, it only does it when it's hot outside and i start the car...doesn't happen under load. :(
https://www.sau.com.au/forums/topic/155164-rough-running-r3434/
actually on occasion my R34 engine does this too (in my R33) has done it twice when it has been over about 40 degree days and parked at work when i have gone to lunch. i thought it was something to do with the heat & my Power FC, a little rev for a min and it clears up fine, but yes also very unbalanced cylinder down sounding.
My engine has around 15,000 km's on it and when i brought it (from a 7000km wreck in japan 2001mdl) i replaced timing belt and everything (as i had it had been sitting since 2002).
Edited by webber
is it running rich? did it happen straight after the 100,000km service? if so is it possible that base timing might be a tad out? sounds much like coils to me, so perhaps if the base timing was a tad out this could have been the straw that broke the camels back so to speak
hey mate,
i had the same problem on my r34 and it was the coil packs. i had heaps of trouble to but until i found the mechanic that i trusted everyone stuffed me around. by speaking to heaps of mechanics i found out that the coil packs on r34s are smaller than r33s that is why this problem happens. many r34s get this problem. Your best bet is to get bigger coils and not the same ones because the problem can occur again.
    • Could someone post some pictures of the factory Jack , tools, spare tire and how they were in a 1998 ER34 2 door skyline originally?
    • UPDATE: Hi all!  As we are getting towards the end of this thread where I’ll showcase final dyno numbers and graph, I wanted to provide an update. Tao from HyperGear has done an amazing job building the custom divided T3 housing for the G30. Communication was flawless, price was great, and now the housing is estimated to arrive in 7-10 days! Very very pleased. I must add, if someone is looking for an affordable turbo and end up reading this thread, I would recommend HyperGear. Genuine brands are the way to go as their proven reliability, predictable performance, and there’s a plethora of information available for specs, flow, and more. This HyperGear recommendation is based on their excellent communication, dedication, and willingness to listen to their customers. I particularly liked their ability to create custom adaptations tailored to specific needs, which is a HUGE benefit over other brands. And if we consider the HyperGear provided dyno results, it adds reassurance knowing their turbos can compete against genuine brands. Next update will be after the dyno!
    • I've previously seen people post up "dress up bolt kits" for RBs but don't remember seeing them specify the full contents. I can only really suggest you grab the verniers and start measuring, and keep in mind the cam cover and timing cover bolts are both quite specific with a wider unthreaded section where the bushes sit, that will make it hard to get aftermarket replacements which tend to be all thread (set screws) or for longer bolts a flat section with a shorter threaded section at the end
    • I believe there was a similar one posted by @duggyphresh. They were re-routing their battery positive cable in the way I am also trying to achieve. Sorry, I’m new to this forum, so was a bit late to the party by a few months and so reignited the old thread, as I wanted to know how they got on with doing it.
