Rough Running R3434
plaetime
 Share
Hey peps, i am new to the forum cause i am having a b*tch of a time getting some straight answers from workshops. Story goes i have an 4 door r34 skyline with the usual mods (boost controller, bov, fmic, 3" turbo back exhaust, aapexi safc2) running 8 psi of standard turbo (175rwkw before fmic and afc2). The problem i am having is that since i had my 100000 service the car runs rough like it has dropped a cylinder, engine light comes on the dash and so does the tcs & slip lights. Almost sounds like a wrx is the best way to describe the sound. the service included timing belt and new plugs (iridiums). i have had the afm, cas, checked out and they are spot on. can anyone help?????? this has been going on for three months, it only does it when it's hot outside and i start the car...doesn't happen under load. :(
actually on occasion my R34 engine does this too (in my R33) has done it twice when it has been over about 40 degree days and parked at work when i have gone to lunch. i thought it was something to do with the heat & my Power FC, a little rev for a min and it clears up fine, but yes also very unbalanced cylinder down sounding.
My engine has around 15,000 km's on it and when i brought it (from a 7000km wreck in japan 2001mdl) i replaced timing belt and everything (as i had it had been sitting since 2002).
Edited by webber
thanks dude was there anything you had done to fix it or did it just go away??? it's kinda starting to piss me off a bit. especially if you are trying to impress the cute office girl looking at you when you start it.
is it running rich? did it happen straight after the 100,000km service? if so is it possible that base timing might be a tad out? sounds much like coils to me, so perhaps if the base timing was a tad out this could have been the straw that broke the camels back so to speak
hey mate,
i had the same problem on my r34 and it was the coil packs. i had heaps of trouble to but until i found the mechanic that i trusted everyone stuffed me around. by speaking to heaps of mechanics i found out that the coil packs on r34s are smaller than r33s that is why this problem happens. many r34s get this problem. Your best bet is to get bigger coils and not the same ones because the problem can occur again.
 Share
    • I am currently going this route. I am curious how much horse power you put behind the cut bell housing? Collins was telling me I am going to crack it and bluh bluh bluh. Because I didn’t buy the custom fly wheel from him. I am looking for somewhere around like 500 hp
    • Forgot to mention that these are the before pics when I first got it!
    • Thanks @PranK for the updated member status, much appreciated! 👍🏼 Now, about those pics… Unfortunately I could only find ones that I took in the dark. I was soon to discover that underneath it wasn’t in the best shape, but it was mine and that’s all I cared about at the time 😆
    • Oh, and only having done this task yesterday, I've now driven the car ~60km since, and while it is hard to avoid placebo effect and confirmation bias, I reckon that some annoyances I had with the way the car has been behaving have improved. Which....kinda makes sense, I guess. If the bushes were really stiff and resisting rotation, they would have been contributing to the effective wheel rate. And if it was more so on one side (which it was, because one side was worse than the other) then.... you might imagine that the additional rate would be asymmetric, and potentially even different between compression and rebound. And so... the car has been twitchy at higher speeds - like freeway on ramps. It really shouldn't be. The wheel alignment is good and there are no (other) known problems elsewhere in the suspension. But at 90-100 on a long sweeping ramp, tiny steering wheel motions would make it feel like it wanted to rear steer. Quite nervous. At lower speeds it would heave about in a manner that it didn't use to. Didn't want to put power down, etc etc. Now...seems to behave better. Am going to have to concentrate on the various corners where it has exhibited weirdness, on the rare occasions when I can get a decent run at them without Methanial getting in the way in his D-Max/Ranger/LDV Van/etc.
