got r32 gtst
haveing isues with it feeling squirmy in the rear any idears
changed shocks
got hicas lock bar
got new rack ends cause they were stuffed as well
then i changed subframe bushes to noltec ones
then got tein flex coilovers cause the ilets on the bottom of my tunable were f**ked
and it still feels like hard core 4 weel steer coming out of corners and big launches
any idears
i was thinking maybee teh camber arms and traction arms
or maybee bushes in lower controll arms
theres nothing else to replace
also maybee weel bearings
reason for this topic is 1 i want to get it sorted
2 does anyone done rear arms on a 32 and know what fits over the teins
i hade a mate with s15 and same flex coilovers brought whiteline rear arms and they didint fit so any help with this much appricatied
ps sorr for all the spelling and grama errors
thanks guys
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/
well I'm not really sure what is causing the play you are getting in the rear suspension. I'm just about to fit some cusco rear upper arms so I think they will fit over Teins or anything like that. I'm also putting in some ikeya formula traction rods. so I guess that answers part of your question. I'm quite sure the cusco arms work fine with japanese coil-over kits.
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/#findComment-2886745
I've had the same problem in the past and found that by replacing everything it fixed the problem. If you replace everything your should eliminate the problem aswell >_< About all you have left to do is the bushes anyway.
Project D upper arms cleared both my cuscos and teins. They are modelled on cuscos so i assume a cusco one will fit too. I haven't heard of anyone having problems with fitting any of the jap (or copy)adjustable upper arms.
Anyway, enough banging on. What height do you have your car set at and what are the alignment settings on the rear end (camber and toe). What tyres are on there?
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/#findComment-2887046
Looks to me like you haven't done the tie rod ends for the HICAS bar, or maybe the ball joints at the hub end of the tie rods, we had trouble with them....caused toe to move by something like 1cm at times....it was terrible tor drive
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/#findComment-2887428
u mean rack ends as i replaceed them these are the things that screw into the hicas rack right
as for tyres yokahama v102
18* 8 235/40/18
um camber about 2.5 deg max adjust
and to to suit tp prevent tyre where
think maybee need to do drives side weel bearing
did passanger about a year ago
https://www.sau.com.au/forums/topic/155170-r32-rear-arms/#findComment-2888591
    • Oh bugger ! Your right ! Good old hydrogen sulfide. Takes me back to the good old school days !
    • I've owned a few scooters over the years, a Vespa PX oil burner was my first scooter, followed by a few others, including a little 50cc BeeWee that I used as a barracks bike, and I've had a blast on all of them, they really are the cheapest for of city/suburb transport around The only issue with scooters in Australia is lots of people look down on them due to their size,  maybe they need a big bike to make up for something else where they are lacking, unlike Europe and Asia where every man an their dog owns one, and now that filtering is legal in NSW, local traffic is never a issue Not to say I haven't owned my share of big cc bikes over the years, but they were for more blasting through the hills or Hwy riding where it needed to sit on Hwy speeds Safety wise, I ride like everyone is always trying to kill me, everyone is running a red, or running stop/give way signs, or generally asleep at the wheel, which most people are duringtheir commute, I also ride really safe, and give myself, and everyone else enough room in case I need to pull some hasty evasive actions, I've done a few rider training days over the years, which has come in handy on more than a few occasions  As for mods, there's nothing really, and yes your right about aftermarket exhaust, all you get is loud and obnoxious noises from them, like every 250-300 cc you hear with a aftermarket muffler, in saying this I did put a rear muffler from a 125 Aprilla on one of my old 125 scooters, it was horrendous and no amount of full face helmet and ear plugs would dampen that noise As for coming from the Harley, and what a overpriced POS that was, I no longer do big rides as my poor old busted joints ache after about 1/2 an hour of riding, long cruises are so much more enjoyable now in a car, so a big bike would be pointless
    • Oh wow, it's easy to forget how cheap these can be. Probably the cheapest way to travel. Though people in cars here tend to be morons and I would not feel very safe. Were scooters ever big in Australia? It used to be the thing growing up in Europe ~20 years ago. 50/70/125ccm Peugeot or Yamaha and some others. Utterly obnoxious Polini race exhausts. Kick stands that slant as much as possible. So loud. So much noise for really not moving very fast at all. But it felt cool at the time. Not sure where I'm going with this, but there is an aftermarket for mopeds! Though I'd have pictured you more for a Goldwing kind of guy after growing out of the Harley.
    • You need to know I am sorry for this.
    • As the MX5 isn't apparently "manly" enough, and I need something for runs to the local shops, and also take to my part time job at the salon, basically I can keep the MX5 away from car parks and stuff......like "flying lockers", I was wondering what I could buy to fix this issue LOL, I pick up a new Yamaha 125 Delight this arvo from Trooper Lu, basically a R1 that you can fit a slab of beer on between your feet, also, it was $29400 cheaper than a R1, so actually it's 2 x better than a R1
